20 Most Recent
New Bright Bright 114 Scale Mud Slinger - Hummer Questions & Answers
I need to find a
A 1:14 Mudslinger requires a 6 Volt battery. Not a 19.2 Volt. Now when you go purchase this battery make sure it says 6 Volt not a 6 Cell. Here is the style battery you need.
http://www.all-battery.com/6vrccarreceiverbattery.aspx
Starting from the top left you can choose the first 5 depending on the shape of the one you have for the RC and the mAh you want. The term mAh indicaters milliamp hours. Basically how long the battery will last. More bang for your buck basically. But they cost more too. They will all function the same. But the ones with less mAh will run out of juice sooner and have to be charged. All these connect the same way from the same style connector. So don't worry about that. Hope this helps.
Regards,
Tony
Holiday express animated train set no.387 was given to me and I have not instructions or track lay-out? HELP
The track layout is simple enough,there are 12 straight peice of tracks and 12 curved tracks. So you can make it one big circle and not use the straight tracks or add 1-6 on each sidewith straight track and you'll have a long oval. Or have 1-4 on each side then add 1-4 after the third curved track of each circlular end to have a big type oval style.Some lites lite up right when you push the power switch on and the remaining lights will work once the train is in motion.
I have a New Bright
I think I'd get one of those chargers that will fit anything- select the right plug and voltage, you're in.
eBay is where I'd check first.
lp
I have a Large scale
yes just look at the boot sales or flea markets ,find a 9v charger with correct end on ,or visit the local chinese emporium and no b?doubt you will find a charger in their of 9v its a fairly common voltage ,9.6?? well 9v will do it fine ,or even a 12v one but dont leave it connected for any length of time
I am looking for a
If the antenna came off of the controller in one day, I would return the whole unit to where you bought it and exchange it for a new unit.
My son has a r/c model Mastercraft made by New
Hi! Best option is to rip all the electronics off and built it up yourself - no replacementparts for those toys. The other option is to sell the boat to me - I would do option 1 with it, because in Switzerland, it seems to be impossible to get such a boat...!
I have 2 radio control
Can you be more specific the rest of your question was cut off. But if you asking if you can switch the freequency's its a yes/no question. The (production) toys come with a complete board and you would have to buy another toy with a different frequency and switch it as there are no aftermarket parts/crystals for sale on Department store toys. You could fine a broken one and switch the remote/electronic in the car. The 2 frequencies are 27mhz/49mxz so if you have one its the other you need. If you purchase a hobby car from a hobby store you can buy a set of different frequency cristals for about $20-$40 And switch them and even for replacement as they go bad from time to time..
