20 Most Recent HEWLETT-PACKARD Hewlett Packard HP Mini 210 with 160GB HD; 1GB Memory Hard Drive Questions & Answers
2answers
Keyboard not working.
why ???? sednely??? take him to mantenuse to replase keybord
7/23/2013 4:06:54 PM • HEWLETT-PACKARD... • Answered on Jul 23, 2013
Spacebar problems
You need to reattach the rubber nipple facing up. It's the part that makes contact with the board to signal to the computer the spacebar has been pressed. Most of them are free floating under the key or even gluing it on would be fine. The keys can be a bit tricky to pop off. Use a plastic pry bar, you an find these online for a couple dollars.
6/21/2013 11:33:46 PM • HEWLETT-PACKARD... • Answered on Jun 21, 2013
I need hirens boot cd on a bootable usb
You need to copy the Hirens boot CD files on an uncompressed USB memory stick.
3/15/2013 6:46:38 AM • HEWLETT-PACKARD... • Answered on Mar 15, 2013
Laptop screen wont boot
If you don't see the initial BIOS screen you could have a problem with one of the following.
  • A bad motherboard
  • Bad memory
  • In some cases a bad Hard drive
Remove the hard drive and memory (both typically removed from panels on the back. Try rebooting. If you get the HP BIOS screen then either the memory or hard drive is bad. Add each back in one at a time and reboot until you find the problem device and replace. I would also power on the computer and use a flash light on the screen. If you see a faint image of what you should normally see then you have a bad inverter. Lastly your motherboard is bad, not a lot you can do to test that.
12/2/2012 5:43:49 AM • HEWLETT-PACKARD... • Answered on Dec 02, 2012
I've installed new windows on my hp mini and now i can't find any internet .. I used wireless before with no problem, it just finded automatically. The button is on etc . Nothing happens , tri
Check driver in Device Manager for Network adapters. Also check network connection (enable) in control panel. Test with cable if no problems are found.
8/27/2012 10:46:00 AM • HEWLETT-PACKARD... • Answered on Aug 27, 2012
Hello. I'm using Windows XP SP2 on my HP Mini
what sort of modem ??? are you using is it a usb wireless modem or an ethernet wired modem ???
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it also the drivers might be installed for this device click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if this driver is not right http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
9/25/2011 8:03:53 PM • HEWLETT-PACKARD... • Answered on Sep 25, 2011
Trying to reboot my hp mini 210. changed the hard
Hi there, The reason your laptop isnt detecting the hardrive during install is cause of the Sata controller. I would advise you download the driver for it at the following site and during the windows installation it will ask if you wish to install aditional drivers and you will need to press F6 so that it can load the drivers for the Controller. http://h30434.www3.hp.com/t5/Notebook-Operating-systems-and/Installing-Win-XP-F6-on-HP-mini-210-1066sb-with-Intel-Atom-NM10/td-p/253374
Hope it helps,
Regards
7/23/2011 6:26:30 AM • HEWLETT-PACKARD... • Answered on Jul 23, 2011
My mini hp doen't be connected through
you might have to open up your network connections click start control panel network connections look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc hope this helps or you could download Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html hope this helps
4/28/2011 4:42:16 PM • HEWLETT-PACKARD... • Answered on Apr 28, 2011
I have HP mini laptop which is already windows7
1. You should a working Windows XP Sp2 setup.
2. Just boot through the bootable pendrive or CD rom whichever you are using.
3. There should be no problem in installation.
4. If installation is completed then download the necessary drivers required from HP website particularly for your model.
3/27/2011 11:34:47 AM • HEWLETT-PACKARD... • Answered on Mar 27, 2011
2answers
When I try to download into quicken the documents page comes up. How do I correct this situation?
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
10/19/2022 4:47:44 AM • HEWLETT-PACKARD... • Answered on Oct 19, 2022
3answers
Back Slash on HP keyboard ProBook
Try now~ Then you can reset your keyboard if you like
5/4/2022 2:32:08 PM • HEWLETT-PACKARD... • Answered on May 04, 2022
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
1/31/2019 6:37:16 PM • HEWLETT-PACKARD... • Answered on Jan 31, 2019
Pano pag ang laptop sa HP ay hindi na mag on pero meron syang power?
please use English, ok?
10/30/2018 1:04:04 PM • HEWLETT-PACKARD... • Answered on Oct 30, 2018
3answers
User manual Hewlett-Packard G2 tablet or the instruction booklet
https://support.hp.com/us-en/product/hp-10-g2/8223709/model/9078231/manuals
this is the manual pdf just download it
10/1/2018 11:15:14 AM • HEWLETT-PACKARD... • Answered on Oct 01, 2018
2answers
My Hewlett-Packard w2207 monitor is showing no input signal when I power it on what does that mean and how can I fix it
1) Reset your computer. 2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in. 3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
5/1/2018 3:23:11 PM • HEWLETT-PACKARD... • Answered on May 01, 2018
HP A6519FH Black Screen Issue: I
what computers.?? 1000's of models over 30 years. made F10 is BIOS screens, so if that works, BIOS. and any screen then the PC is not booting. try booting to CD? *(a free linux live cd?) as a test. if that works run HDD tests. next ill stop here, if you can get this far, we go to next step F11 HDD reload the OS, if PC is 2006 or newer from HP.
2/1/2018 12:20:26 PM • HEWLETT-PACKARD... • Answered on Feb 01, 2018
Ce 3700, no model HP stated
Try again with the model number
1/30/2018 12:32:03 PM • HEWLETT-PACKARD... • Answered on Jan 30, 2018
My laptop hp compaq 6715s, the battery is charging
what is a device? did you mean PC, a collections of devices and chips:? a PC Is not a DEVICE it is a system.(or machine) why in the world not buy a new battery first? if charging fails. mine sometimes go bad even 1 year old, when I abuse it. and I fully expect that, if you read the battery makers pages, youd learn how that happens' (cycling the snarf out of it) if i remove the word DEVICE and add LAPTOP OR PC THE ANSWER IS THIS. IF the Pc does not run with the battery (main big) out ! the power pack is bad. the PC will run forever on AC power, a fact, !!! I do so all the time, or even the wrong AC pack used, (mixed up with other pc:) get a new pack, get one matching your systems, needs (watts) the laptops can come with 5 processor options and 4 graphic chip options, the worse mix is 100watts, HP will tell you that match. but only if YOU tell your full service tag data.... that magic, nnnnnnnABA# number tells the HP pro what is inside this laptop and what power park is right or just buy the 19v, 100watt pack. here is real HP, fixya is NOT. they can match you up as can the hp PARTS SURFER, https://h30434.www3.hp.com/
1/24/2018 1:56:50 PM • HEWLETT-PACKARD... • Answered on Jan 24, 2018
2answers
How to fix the sound of HP pavilion dv6345us
sure, get the Correct HP driver for this exact pc but, but but...The windows sounds are dead. (do that yet>, CP + sound test)CP = control paneltry to know , most HP made, dv6345us, can have 3 sound chips as an option day 1 new!what you have is clearly stated in the service tag that you did NOTpost, the number ending in ABA# is THAT number.the chip and PC and the unstated OS all must matchwindows what? you never said so i cant match that either.VISTA????????? vista 32 bit or 64????????but the other way is what, sure, guess.read the drivers at HP and try all there.for sound chips (aka audio)This HP computer is 11 years old. now. (2007)HP dropped most support on it this old, (SOP) one sound chip is Conexant AC -Link Audiolets say you said (service tag) RV214UA#ABAand you said VISTA> what works there.the secret is deep, lacking full spec, from HP.finding Conexant drivers is not easy, lots of hits all virus sites now.lets first look .does device manager show it as bad.CP+DM see sound there. is it red, yellow or Unknown marked.go to CP again control panelclick sound is the Conexant still there.the window for sound has a speaker is it selected?select speaker then properties lower right.then pick enhancementshit checkmark, disable all sound effectsclick tab levels, turn up volume.can you do all that, i bet not, its got bad drivers for this chipVISTA btw is dead so asking MS to update driver is dream of dreams, hopeless, now and for sure forward.you dont have the HP install disks so that source too is missing.,leaving you , VISTA and MS and HP and conexant in the lurch.if microsoft was not dead and your internet was alive (is it)the remove the driver, and reload, it under device manager.it then magically PnP reloads from MS but not if the MS driver servers are off line as they sure are. (1/2 or all) (ms secret this is)Hard this is,::::, 1ST OFF, is HP ended support,ON YOUR PC NOW.2nd VISTA support has ended at MS. (double dead)3rd factor (bad) IS Conexant maker of chip and their Driver. IS DEAD. TRIPLE DEAD.SHORT WHY>?synaptics Bought out Conexant in 2017, and shows no support NOW. FOR THAT. the Snaptics web site lists nothing on the words driver or conexant. zero support, but do call them,,,? SO that ends that foray. leaving all those malwares sites offering this driver, only. ? many we can find it this magical way. the FAMOUS DRIVER PACKS site. (all safe ask) the one place on earth with no malware is here.this is the vista set 32bit only 64 is on other pagethere are 15 drivers for Conexant. there. get them try them.end storyhttp://driverpacks.net/driverpacks/windows/7/x86/audio/11.11
1/5/2018 4:29:57 PM • HEWLETT-PACKARD... • Answered on Jan 05, 2018
HEWLETT-PACKARD Hewlett Packard HP Mini 210 with 160GB HD; 1GB Memory Hard Drive Logo
15 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
spacebar problems
  • Computers & Internet
