Check the speakers, check the wires, check the set connections (antenna) and if all is good the fault must be inside the set, in that case it would be wise to go no further and let the repair shop handle it.
Did you count your disks when it opened? Maybe one is laying inside blocking the tray from going back... did it open o.k. ? If you had to pull the tray out and now it won't go back you may have a bad motor or belt.
Your asking for a service manual I presume. I do not have one, but one can be downloaded from here
http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=AG-360
Good Luck
The repairability of the Teac CR-H100 depends on the specific issue it's facing. Many electronic devices, including audio units like the Teac CR-H100, can be repaired if the problem is identified and if replacement parts are available. It's recommended to contact Teac customer support or a certified technician to assess the specific issue and determine the feasibility of repair based on the unit's condition.
Here are some troubleshooting steps you can try: Power source and wiring: Make sure you are using a reliable power source and the correct power cord for the Teac NP-H750. Sometimes using faulty outlets or wiring can slow down the power on time. Firmware update: Check if there is a firmware update for the device. Manufacturers regularly release firmware updates to fix performance issues and improve performance. Updating the firmware can help fix the slow power-on. Reset the device: Try a factory reset on the Teac NP-H750. This process can help eliminate any software bugs that may be causing the slow startup. Network connection: If your Teac NP-H750 is connected to a network, check the network settings to make sure you have no problems connecting to the Internet. Sometimes network issues can delay the startup process. Check for hardware issues: Inspect the device for any damage or loose connections that could cause a delay during power on. Check the power button and other controls carefully for proper operation. Power saving system: Check the power saving system on the Teac NP-H750. If the device is set to quickly go into standby mode, it may take longer to turn the power back on. Use Support: If none of the above solutions work, consider contacting Teac Customer Support or their Authorized Service Center for further assistance. They may have specific troubleshooting problems or know general issues with your model. Please note that products must be made with care, as modifications to the product or unauthorized repair attempts may void the warranty. If your Teac NP-H750 is still under warranty, it is best to contact the manufacturer
You give no clue what the part is, but a link to TEAC spares is in the link.
https://www.google.com/search?q=Teac+Part+No.+1977182R-50
All questions need 'make model (what it is) please for the host item and what you are looking for. The link suggests it is the optical drive and they are readily available.
ON THE DRIVE WHEEL SHOULD BE A COIL SPRING AND IF GETS DUST IN MAKES THEM TIGHT WHICH SETS OFF AUTO STOP,, TRY BRUSHING DRINE WHEELS WITH A MINUTE AMOUNT OF SILICONE POWDER AND ENSURE THEY TURN FREELY
You can easily load images, videos can only be uploaded if they are on YouTube. If you have the video uploaded to another place you can just put the link in.
Please don't type in all CAPS, it is considered SHOUTING and rude, plus it is harder to read especially with so little punctuation. It all runs into one sentence!
You should have returned it when you realised the CD player didn't work. Your issue now can easily be fixed. It is likely to be damaged capacitors just due to age. Nice little audio system.
https://www.google.com/search?q=TEAC+audio+repairs+near+me
