20 Most Recent
VeriFone 355 Thermal Printer Questions & Answers
I need a drive for
unfortunately,
the driver for your Verifone printer 355 is not available anywhere online.
The manufacturers (Verifone) of this printer did not make it available. I went
further searching and couldn't find any.
I would suggest you
contact the manufacturer of your Verifone printer 355 via phone or e-mail and
request for the driver from them. They might give it to you or direct
you to a dealer where you can get the driver.
This is the best you can do to get the Verifone printer 355 you are requesting for.
Good luck.
Hellp me to downloud drievr
Go to the Verifone website, look up your printer, and you should find what you need in your Support section.
Have verifone 801 printer - prints game and fish
NOTE: The inside cover of the printer has medialoading instructions for vendors.
- Open the lid of the printer by pressing in on the two (2) Blue buttons on both sides of the printer, and lift upward.
- Press down on the Green Printhead Latch, and raise the Printhead Carrier assembly to a vertical and locked position.
- Remove the Ink Ribbons (Supply and Take-up Hubs/Spindles) from the Printhead Carrier by pushing in, and lifting up.
- Slide both ribbons off the hubs, and discard them into the trash.
- Slide an empty core onto the take-up hub. (The attached new roll of ribbon includes a new supply hub.)
- Unroll a 1-foot length of ribbon. (The foiled side will need to be facing the Printhead and rollers.)
- Insert the supply hub/ribbon into the rear spring-loaded spindle.
- Starting from the back of the Printhead Carrier, thread the take-up hub/core in between the black guide bar and the two (2) aluminum rollers.
- Continue past the Printhead, and over the 3rd aluminum roller.
- Insert the take-up hub into the spring-loaded spindle 'star' hole.
- Position the license paper (media) over the rubber roller to the edge of the opening with one hand.
- With your other hand, lower the Printhead Carrier to its locked position.
- Close the printer lid.
Vx610 verifone change prefix to dial 9
It all depends on the application. It would be best to contact your technical support service to have the prefix added to the programing parameters they are hosting for you. Then you can download the new parameters using your 9 prefix by editing the *ZP prarameter to include 9,18#########. To add the , press * ALPHA.
