20 Most Recent VeriFone 900 Matrix Printer Questions & Answers
2answers
Drivers for a verifone 250 printer in winxp
You can try to find it at this link
http://verifone.50webs.com/
5/3/2017 12:02:37 AM • VeriFone 900... • Answered on May 03, 2017
0answers
We changed the paper roll on our Verifone 900
You might have changed the type of paper or You have to reseat the paper roll make sure it fits correctly into the printer
6/7/2011 8:38:50 PM • VeriFone 900... • Answered on Jun 07, 2011
Our VeriFone 900 printer has a brand new ink
check whether the cartridge is rolling coz you might have not placed it correctly
6/7/2011 8:12:52 PM • VeriFone 900... • Answered on Jun 07, 2011
Verifone 900 receipt copy faint changed paper/ink
You have a bad ribbon, I would get a new one and clean the roller
3/16/2011 2:18:17 PM • VeriFone 900... • Answered on Mar 16, 2011
Verifone 900 blinking power ligh
On the P900 printer, this blinking light always means "service". The P900's are notorious for software issues after they have aged. Every time we encounter this issue (very common), the only solution is to send it in for repair (usually ~$75).
9/5/2009 4:27:14 PM • VeriFone 900... • Answered on Sep 05, 2009
Spits out Paper
This is an internal problem that can only be repaired by a Verifone service center or company with verifone service experiance.
8/2/2009 12:35:32 AM • VeriFone 900... • Answered on Aug 02, 2009
Help
open the printer paper holder for a verifone P900
2/2/2008 12:57:38 AM • VeriFone 900... • Answered on Feb 02, 2008
Verifone printer 900 - How to find the current settings
There are 4 DIP switches located underneath the paper holder (bottom).
SWITCH1: ON => Even parity, OFF => Odd parity.
SWITCH2: ON => 8bit word (no parity), OFF => 7bit word.
SWITCH3-SWITCH4: ON-ON => 1200baud,
ON-OFF => 2400baud,
OFF-ON => 4800baud,
OFF-OFF => 9600baud.
Good luck...
__________
Samir.
1/31/2008 10:46:47 PM • VeriFone 900... • Answered on Jan 31, 2008
Problema na maquina verifone vx680
Tente fazer reset de f?brica. Remova o cart?o sim e reinicie.
2/23/2022 5:05:39 PM • VeriFone Office... • Answered on Feb 23, 2022
Hellp me to downloud drievr
Go to the Verifone website, look up your printer, and you should find what you need in your Support section.
5/3/2017 1:15:43 AM • VeriFone Office... • Answered on May 03, 2017
Have verifone 801 printer - prints game and fish
NOTE: The inside cover of the printer has medialoading instructions for vendors.
  1. Open the lid of the printer by pressing in on the two (2) Blue buttons on both sides of the printer, and lift upward.
  2. Press down on the Green Printhead Latch, and raise the Printhead Carrier assembly to a vertical and locked position.
  3. Remove the Ink Ribbons (Supply and Take-up Hubs/Spindles) from the Printhead Carrier by pushing in, and lifting up.
  4. Slide both ribbons off the hubs, and discard them into the trash.
  5. Slide an empty core onto the take-up hub. (The attached new roll of ribbon includes a new supply hub.)
  6. Unroll a 1-foot length of ribbon. (The foiled side will need to be facing the Printhead and rollers.)
  7. Insert the supply hub/ribbon into the rear spring-loaded spindle.
  8. Starting from the back of the Printhead Carrier, thread the take-up hub/core in between the black guide bar and the two (2) aluminum rollers.
  9. Continue past the Printhead, and over the 3rd aluminum roller.
  10. Insert the take-up hub into the spring-loaded spindle 'star' hole.
  11. Position the license paper (media) over the rubber roller to the edge of the opening with one hand.
  12. With your other hand, lower the Printhead Carrier to its locked position.
  13. Close the printer lid.
7/23/2015 4:40:40 PM • VeriFone Office... • Answered on Jul 23, 2015
Vx610 verifone change prefix to dial 9
It all depends on the application. It would be best to contact your technical support service to have the prefix added to the programing parameters they are hosting for you. Then you can download the new parameters using your 9 prefix by editing the *ZP prarameter to include 9,18#########. To add the , press * ALPHA.
6/11/2014 10:37:25 PM • VeriFone Office... • Answered on Jun 11, 2014
Loading paper
load paper and press the green button.
5/22/2014 5:42:26 PM • VeriFone Office... • Answered on May 22, 2014
VeriFone 900 Matrix Printer Logo
22 questions posted
Top VeriFone Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • VeriFone Office Equipment & Supplies
Most Popular Question
changed paper roll our verifone 900
  • Office Equipment & Supplies
