20 Most Recent
VeriFone Omni 3200 Printer Questions & Answers
How do I know what paper to get?
Here are the specs of the paper that you need:
Color:
White
Material Type:
Thermal Paper
Size:
2-1/4 inches x 85 feet
You can buy this paper
HEREThank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
My credit card machines show
There was a miscommunication between your terminal and your processor. You need to call them to verify batch totals and possibly update some info inside the terminal.
Hellp me to downloud drievr
Go to the Verifone website, look up your printer, and you should find what you need in your Support section.
Have verifone 801 printer - prints game and fish
NOTE: The inside cover of the printer has medialoading instructions for vendors.
- Open the lid of the printer by pressing in on the two (2) Blue buttons on both sides of the printer, and lift upward.
- Press down on the Green Printhead Latch, and raise the Printhead Carrier assembly to a vertical and locked position.
- Remove the Ink Ribbons (Supply and Take-up Hubs/Spindles) from the Printhead Carrier by pushing in, and lifting up.
- Slide both ribbons off the hubs, and discard them into the trash.
- Slide an empty core onto the take-up hub. (The attached new roll of ribbon includes a new supply hub.)
- Unroll a 1-foot length of ribbon. (The foiled side will need to be facing the Printhead and rollers.)
- Insert the supply hub/ribbon into the rear spring-loaded spindle.
- Starting from the back of the Printhead Carrier, thread the take-up hub/core in between the black guide bar and the two (2) aluminum rollers.
- Continue past the Printhead, and over the 3rd aluminum roller.
- Insert the take-up hub into the spring-loaded spindle 'star' hole.
- Position the license paper (media) over the rubber roller to the edge of the opening with one hand.
- With your other hand, lower the Printhead Carrier to its locked position.
- Close the printer lid.
Vx610 verifone change prefix to dial 9
It all depends on the application. It would be best to contact your technical support service to have the prefix added to the programing parameters they are hosting for you. Then you can download the new parameters using your 9 prefix by editing the *ZP prarameter to include 9,18#########. To add the , press * ALPHA.
