20 Most Recent
Thomson 28VK25US TV Questions & Answers
My Thomson TV 28WF401G is
U have tools like a soldering Iron and roll of solders?Can u also do basic soldering works?Yes take the tv aparts and resolders the FBT-(flyback transformer) that the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).Also the tv video board that the board that hook up to the tv CRT-(tv tube) tube neck hook on to this video board.Resolders that board too.70-80% will get the tv working again.
TV just shows blue language
hi did u find a solution. i am currently having this problem an am desperate to fix it as it is my freindsx tv an somehow i did it. we also have no remote. please let me no.
My TV is constantly changing
most of case i found the problem in the front panel soft keys when you measuer the vlaue it will show sevaral MEGA ohms
pls replace the all touch keys in the front panel control board
it not expensive
Is this tv hd ready
Well, if it has a cable connection on back, it is HD ready......hope this helps....
Tompson 32WX411t
Sounds like high voltage failure and if the set is about 10 years old it is not worth putting any more money into it
Stand by
Hi
I have very little knowledge of TV electronics but I have worked on other electrical devices,
I had a very similar problem with my Thomson 32" TV (I had a whistling noise before it went into standby). and am pleased to say I have cured the problem myself!!
If you have a soldering iron and the ability to use it I will describe what I have done.
Obtain access to the main printed curcuit board (I left my TV unplugged overnight to enable any residual power to subside). on the main board (on mine upper left 1/4 of board looking from the back) you will see a circular group of solder joints (about 9 or 10 joints) that appears to be the main component that connects the curcuit board to the screen,check these joints to see if they have gone dry (they will appear to have a ring around solder joint)if so you might have found your problem, desolder these joints and remake with a good quality solder joint.
I carried out my repair 5 days ago and am pleased to say my set has not gone into standby since.
best of luck
Stuart
Rear Projection
TRY contacting Parts suppliers like, VANCE BALDWIN ,TRITRONICS, MCM ELECTRONICS AND HERMAN/ PANSON For a few Charlie
TV Thomson Scenium 28WF64E L
See that any of the buttons are pressed or any thing is shorting any of the switches or wires or PCB in your Television
Thomson 44jw611s rear projection tv
hi there, red light flashing means a shorted parts on the unit, do some test, check the horizontal sec, check the FBT if ok else buy a new one. ty
SANYO AVM-3289G no vertical deflection
It isn't a transistor, It will be an I.C. with a part number that
probably starts with an LA_ _ _ _ . It will be on a heat sink and
be in the vicinity of the connector going up to the yoke. Try
replacing that. But first, check all the electrolytic caps around
it for testing dry (sorry - takes a special meter to do it in circuit)
or just replace them. May have lost power to the I.C. as well.
Look the I.C. up in the free NTE crossreference at nte.com get a
diagram of its pinout to find what pins the power and outputs are on.
