20 Most Recent Ativa LD800 8-Sheet Cross-Cut Shredder Questions & Answers
Is sounds like you have a paper jam. Most jams are pretty much the same. First, try running the blades in REVERSE, that is done by using the on/off, selector switch.
If that does not solve the problem, Unplug the unit from the electrical, remove the top part from the basket. Pull out as much of the paper from the top and bottom that you can.
Replace the unit on the basket (make sure it is facing in the correct direction) and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then try running the unit. If the motor does not come on, there is a fuse inside the machine that may need to be replaced.
Once you have solved the problem, you should oil the blades after every hour of use, it really makes it easier on the blades.
Also, there is an internal "heat switch" in the machine that will shut it down for about 90 minutes if the motor gets to hot. It is a safety factor in case you get something stuck, like a person wearing a tie, etc. After the machine has cooled down, turn the on/off switch to off and then back to on.
If that does not work, try their Customer Service at:
http://www.ativaproducts.com/contact.html
Ativa Office... | Answered on Jul 19, 2014
That's good. It is better to have the paper trays full rather than empty.
Office Equipment... | Answered Yesterday
how would anyone know??? we dont know what it is first of all and second we cannot see it here can we??? good luck
Ativa LD800 8-Sheet Cross-Cut Shredder Logo
1 questions posted
Top Ativa Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ativa Office Equipment & Supplies
Most Popular Question
ativa shredder model md 1250 became
  • Office Equipment & Supplies
