20 Most Recent Thomson 14MG135 14" TV Questions & Answers
May i know the number of fly back transformer used in jvc av-21L11?
Download the service manual to it. It will have all details.
3/12/2016 12:14:02 PM • Thomson 14MG135... • Answered on Mar 12, 2016
JVC 29 inch Color tv Model no 29ss16 flyback no JFO 501-21168
Just try this link. It has circuit diagrams to some popular brand CRT TVs. Hopes that it might help you find out the exact number of the flyback transformer. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
1/16/2014 6:35:42 PM • Thomson 14MG135... • Answered on Jan 16, 2014
Problem coler tv
What is the problem with your TV. Provide more details please.
3/22/2013 10:53:46 AM • Thomson 14MG135... • Answered on Mar 22, 2013
I need the schematic diagram for 14mg135 thomson tv
Hi,May I know if the chassis number of your TV is ITC008? If not, please let me know what its chassis number.Jdvillanueva
2/25/2013 7:59:35 PM • Thomson 14MG135... • Answered on Feb 25, 2013
EHT NO. OF SONY T.V. MODEL KV-L34MF1 AND APPX.COST OF IT
The line output transformer to your TV should be checked and replaced.
8/28/2012 12:20:07 PM • Thomson 14MG135... • Answered on Aug 28, 2012
How to program my quadra surf remote to hitatchi television
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
7/15/2012 4:21:21 PM • Thomson 14MG135... • Answered on Jul 15, 2012
Top of the screen its linearity problem
You have to get into its service mode adjustment window to adjust this. Service mode adjust window, is entirely different to that of Menu window. Just visit this site, and pull up older posts there. You can see the proceedings to how to enter service mode to Thomson TVs. For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you. Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
6/5/2012 2:37:42 AM • Thomson 14MG135... • Answered on Jun 05, 2012
How to tune thomson tv 14MG135
first is to get it from AV mode which suggests it is on one of the rear audio/video inputs.If no source or Tv video button on remote look in the menu--once off the AV input it should be able to tune.Direct hookup with cable or what?
5/2/2012 6:34:30 PM • Thomson 14MG135... • Answered on May 02, 2012
14MG135 4:3 14" Television 14 in. Is this a
No this is not a digital tv. You will need a converter box/set top box. I am posting the specifications. Where it says tuner it would have to say atsc and/or qam for it to be a digital television
Product description Product Identifiers Brand Thomson Model 14MG135 MPN 14MG135
Key Features Screen Size 14"
Technical Features Screen Type Non-Flat Screen Aspect Ratio 4:3 Built-in Tuner NTSC, PAL, SECAM Adjustable Color Temperature Without Adjustable Color Temperature
Connectivity Front Input Connectors Audio (RCA) x 1, Composite x 1 Rear Input Connectors RF x 1
Audio Features Number Of Speakers 1 Speaker Power 1 x 3.5 Watt Audio Type Mono Subwoofer Without Subwoofer Audio Leveler Without Audio Leveler
Miscellaneous OSD Languages Danish, Dutch, English, Finnish, French, German, Greek, Italian, Portuguese, Russian, Slovakian, Spanish, Swedish, Turkish Parental Control Proprietary Sleep Timer With Sleep Timer Remote Control Standard Additional Features Headphone Jack
7/19/2011 4:57:53 PM • Thomson 14MG135... • Answered on Jul 19, 2011
How to unluck my 14"
Sorry,u can't unlock secret codes.Tries unplug,replug tv an hour later.Tv is reseting back to factory default,might erase the codes too?
9/9/2010 4:46:29 PM • Thomson 14MG135... • Answered on Sep 09, 2010
Remote control broken and sleep timer on
Hello
I don't have a solution, but have the exact same problem, sorry!
did you find out how to solve it? probably buying a remote control would do it?
3/1/2010 8:03:26 AM • Thomson 14MG135... • Answered on Mar 01, 2010
2answers
Retuning having moved to a new area
blue screen is due to problem in blue video circuit. please check 1 supply to blue video ckt. 2 crt base loose. 3 components in blue video ckt. 4 loose contact in blue cathode ckt in crt base. 5 blue video transistor. 6 signal coming to blue video from signal processor. 7 signal processor ic. good luck.
2/28/2008 11:18:28 AM • Thomson 14MG135... • Answered on Feb 28, 2008
Some part of tv has been fused causing no picture
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
2/14/2008 6:10:12 AM • Thomson 14MG135... • Answered on Feb 14, 2008
Thomson tv remote red light why blinking?
Could be failing power supply
7/24/2021 5:40:57 PM • Thomson... • Answered on Jul 24, 2021
My 32 inch led Thomson turn upside down after I changed its damage screen. Any solution please
yes find another repair guy
4/17/2021 3:37:56 PM • Thomson... • Answered on Apr 17, 2021
Thomson 14MG135 14" TV Logo
24 questions posted
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Televison & Video
Most Popular Question
jvc 29 inch color tv model no 29ss16
  • Televison & Video
