20 Most Recent
Nokia 5250 Cell Phone Questions & Answers
I have forgotten my lock
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Touch screen not working
Try to replace your Nokia 5250 touch glass, it should work. Or you can ask somebody who is professional at repairing service for help.
I have lost my nokia 5250 restore code how can i get it
thing is you cannot get it back unless you remember restore cord. but you can reset it follow the instruction
Hi there. I will help you on how to do this process called flash restting, since you stated that you forgot now your master code for this, the said process only will helped you as of the moment., but first things you need to have a full charged for your phone`s battery for this will not work well if not fully charged.
Here`s how to do it,
*Remove the battery, and then wait for about 20 min or so before putting it back
*Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
* switch ON the phone.
* Do not let go the three keys until you see the Welcome screen displayed and just let it complete the boot process
hope that you will reset it
Unlocking code
Hi if you are looking for network unlock code to unlock your Nokia 5250 mobile from network lock ..Then have a look at sites like
http://www.onlinegsmunlock.com/nokia-5250/rs1wp9/ here they are rendering unlock code for all mobile models at reliable cost .You first verify that whether they are rendering code for your country and network provider .If yes then pay for it and unlock your phone ....
Touch pad not working
have you tried a phone software update only if the phone has not been dropped or the digitizer cracked. if not then software update should solve the issue.
How to reinstall phone software by computer
On your computer install Nokia PC Suite and run it. Fully recharge the phone battery. Connect to the computer thru USB cable. In PC Suite backup the data of the phone. remove the SIM and the memory card. Now update the firmware. Follow the instructions, word to word. After some time you will be told that the firmware has been updated. Cheers.
Hard reset
Take out the battery, and re-insert it after 30 minutes or so.
I want to unlock my nokia 5250 phone
Hi, You can unlock your Nokia 5250 using unlock codes!!! Unlocking using codes is easy and also safe!!! You can get the codes from your service provider or from any online sites!! I would suggest
mobileunlocksolutions.com ,they provide perfect codes at reasonable price!!! By specifying your phone's manufacture, model, country and network, you'll be able to get the codes!!!
Unlock
Use unlock code to unlock your Nokia 5250. Get the code at the site
Mobile-Unlocker.com ,and unlock it using unlocking instructions which is given in the site itself. then you can use any GSM network with your mobile without any problem.
