20 Most Recent
FocalPrice MX Google Android 4.2 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module Questions & Answers
My android mx box as frozen wont show nuthing only start up mbox how do i get past it
Unplug from mains ...then reconnect...go into settings and check if the Ethernet or wifi is connected....sometimes restarting the router puts things right...without that you can't proceed....if you have not already done so download kodi version 14 as this seems to be quite stable.once downloaded go into API installer and direct to your internal sd to locate the Kodi apk file.once installed you can then set up your ad dons.a quick simple way is to use a community build from tvaddons.ag.if you are someone who bought from droidsticks you can use the droid stick wizard providing you still have the codes.get back to me if you are still stuck.
Got sound, but no picture & cannot get into setting, help
You can try using the RCA connections as it sounds as if hdmi is switched off.this will be the yellow plug into a scart socket adapter.
if you are still having connection issues try a different hdmi cable and or reset the box using a paperclip near to USB sockets.
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
