20 Most Recent
Brother HL 1650 Laser Printer Questions & Answers
"Service Call Error E54"
This error code indicates a fault with the Main Motor. Either it's jammed or unusable. Unplug the printer from the power source, leave it for around 30 minutes, . While it's turned off, remove the cartridges, check for any damage, then put them back in. After tha, then reconnect it to the power and turn it on again. If this still doesn't clear the code from the display then you'll need to see a Brother service agent to have the main motor replaced.
E52 Error - Service Call
Error 52 is a malfunction of the laser motor. Laser replacement is the only fix. The last one I changed cost around $80.00
The printer will print OK
Dear Glenn27,
As you mentioned, printer works fine normally however the issue is only while printing emails.. so I would like to know the email program that is in use .. I mean, do you use Outlook, Outlook Express or webmail or Lotus notes etc..
If this is a repeated question then I would like to apologies as we experts are not allowed to peep into other experts' solutions so I cannot see the responses by the previous expert.
Also please let me know the following printer settings ..
AUTO WRAP, RIGHT MARGIN, LEFT MARGIN,
What happens when you copy the email text to a standard text editor like Notepad or Ms Word and then try printing .. does it still print with right margin extended?
Waiting for your response.
Regards,
Srinivas
Service call Error E50
Just turn of the printer and turn off the system, after a few min turn on both, i thing it will solve or contact me
Error E50 model HL-16
you just diagnose your printer of their software tools...so that you can identify the error made...or just look the manual on how to reset the default setting of the printer....
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Things To Do When Brother Printer Shows Offline Errors
Troubled with issues via brother printer goes offline frequently? Here are few things to do when fixed.
- Begin with checking whether the machine is turned on or not
- Sometimes when you find your brother printers screen is all blank the indications could be that the machine is turned off
- Check the device properly and make sure that it wakes up from its sleep mode.
- Note that in case you cannot turn on the machine it indicates some hardware problem and does none of the below mentioned troubleshooting steps will work.
- In case there are any other kind of error messages read on the LCD screen please follow the mentioned on screen instructions to troubleshoot it
- Another trivial brother printer offline issue occurs because of paper jam
- To fix a paper jam first check on the input and output paper trays check the add cover
- Is the paper jam still exist unplug the printer and check inside the printers to remove any torn piece of paper carefully
- Printer is properly connected
Sometimes your brother printer not printing issue is contributed when the printer is not properly connected to the network or computers. To check
- If you are using any USB cable make sure the cable is connected to both the ends on printer and computer
- If using Ethernet cable make sure the cable is properly connected to the router and computer and you have a working internet connection
- The wireless connection users also should check their network connectivity
- Make sure that both your computer and your printer is connected to the same network
- Set your printer as default
To set your brother all in one printer as default follow the steps
- Go to control panel and from there go to devices and printers
- Click on the icon of your printer
- From the sub menu choose option set as default
- Deleting all pending print jobs
- To delete all pending print jobs from brother inkjet printer, go to control panel and from their go to devices and printers
- Right click on the brother printer icon and choose the option see what's printing
- Select option printer and finally choose cancel all print documents.
- Is the cancelling option is grayed out then click on option use as administrator
- Enter your option use as administrator and click on yes.
- To fix printer offline errors on Mac
- To fix brother printer offline mac error go to system preferences from Apple menu and on their go to option printers and scanners
- Select the brother printer machine from the list of drivers
- Make sure that the correct driver is selected to be used.
- At the top of the dialogue box name of the default printer icon is given
- Make sure name is printer name + CUPS
- Click to add printer and then quit system preferences
In case of unresolved issues call experts for further guidance
https://printeroffline.support/brother-printer
Lampu indikator toner menyala
gan mohon bantuan pencerahannya, di kantor saya memiliki printer LQ 2190 saat ini memiliki kendala lampu indikator merah nyala semua dan printer tidak bisa nge print, itu di sebabkan kenapa ya gan, dan bagaimana cara memperbaikinyamohon bantuan pencerahannya ya gan
