20 Most Recent
Brother DCP 1400 All-In-One Laser Printer Questions & Answers
Error 71 / It is not working.
This error indicates that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Is there any technician to
Please elaborate your problem providing us with more details and the complete make and model number of the product.
Thanks for using FixYa.
The whole face become light
In some printers a black page can be occur when the charger corotron is broken or not properly connected. Examine the charger corotron to see it is broken. Usually it comes with print cartridge or photoreceptor unit; replace the print cartridge or photoreceptor unit with a new one. If the charger corotron is not broken, or cannot be seen to check, try removing and reinstalling the print cartridge or photoreceptor unit, as the electrical contacts between the removable unit and the main part of the printer may not be connecting properly.
Sometimes ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. but the most common source of light ghosting is developer starvation. If you ask a laser printer to print an extremely dark or complex image, it can use up so much toner that the toner cartridge won’t be able to charge enough toner to print the next image. The proper solution is to use less toner by doing the following:
a) Use low resolution
b) Chang the pattern
c) Print a completely blank page prior to the page with the ghosting image.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
The whole paper face is
This is due to tonner catridge got over or near to end. Replace the tonner catridge will resolve your problem.
Revert back for more assistance.
Brother control center 4 won't open on my computer
This may help others with scanning issues:
I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Genuine brother ink cartridge not detected by printer on DCP J315W printer
This is a common occurrence for these machines. They can get confused when cartridges are changed before they read as empty.
To correct this.
1) Unplug the printer from both the Power and Computer and remove all cartridges closing the cartridge access panel.
2) Plug the printer into the Power only and turn on. The machine will complain about no cartridges, this is fine.
3) Open Ink access panel and insert the first cartridge (Black is most common and close the panel.
4) The machine will complain about the missing cartridges. Open the panel and insert the second cartridge in the sequence and close the panel again.
5) Repeat the process for the third and fourth cartridge.
6) Once all cartridges have been installed the printer will ask if you have replaced the cartridges. Say no to the Black, Cyan and Yellow but yes to the Magenta and it will display the correct readings.
If this process fails to read the cartridge still then there is something wrong with the sensor inside the machine which probably means new machine.
DCP-J315W shows "Unable to Init 4F"
Turn off the printer and unplug it from the power. Then press and hold the power button for 1 minute. Now release the button, plug in the printer and turn it on and see if the error clears.
If it doesn't fix the issue, you probably have to replace the cartridges. They will cost about $65. Good luck!
