20 Most Recent Zenith B25A02Z TV Questions & Answers
Firmware Zenith Smart Television.
Not enough information here. Suggest you go to the manufacturer's website and have your TV model number ready. Informazioni insufficienti qui. Ti suggerisco di visitare il sito Web del produttore e di avere pronto il numero del modello del televisore.
6/22/2022 12:20:02 PM • Zenith B25A02Z... • Answered on Jun 22, 2022
Dvd IN lOGIC TV is not working
Nope - the player laser assembly has lost its ability to recognize and read the disk. You replace since repair is not cost effective. If player is not proprietary you may be able to drop in there a normal computer dvd player to do the job of playing back. It will work!!!!!!!!!!!
8/26/2017 2:05:51 PM • Zenith B25A02Z... • Answered on Aug 26, 2017
I have a Zenith Model B25AO2Z tv and programmed it through my cable remote. I just got a new cable remote and the first step to program a tv is to turn on the tv. I can't do that because the t
Have you ever tried to fix tv remote? Most of the remotes don't work due to broken led connection (Red circuled area). Try to resolder it, may be you might work it. 25290459-3h5pkc2unruv115jj1tsixdi-2-0.jpg
11/20/2014 1:13:22 AM • Zenith B25A02Z... • Answered on Nov 20, 2014
Noise in picture
NOISE IN THE PICTURE., IS WHEN YOU., NOTE THAT THE IMAGE IS CLEAR., BUT IS VERY GRANULADA., AND THIS IS DUE TO POOR RECEPTION SIGNAL SELECTOR CHANNEL IS DAMAGED.
3/27/2014 10:53:10 PM • Zenith B25A02Z... • Answered on Mar 27, 2014
Factory reset
Refer its user manual. It have details about how to change the language display.
12/14/2013 7:57:50 AM • Zenith B25A02Z... • Answered on Dec 14, 2013
Our cat accidentally step on the remote control of
Contact any service technician. google.com/+GopakumarGopalan
11/2/2013 12:51:10 PM • Zenith B25A02Z... • Answered on Nov 02, 2013
manual
2answers
CAMPORT STUCK on???
I had ot go online to buy a remote control to use with my zenith concierge tv. It is the same model # as yours. I ended up paying almost 40 dollars for a remote made by lg who I believe bought out zenith. I believe you could problably just get a universal remote and get the same thing accomplished. I can do everything with the remote I ordered except the one thing I wanted it for and that is to turn up the volume. It says on the menu, custom, not preset, but it still will only go up halfway no matter what I do. I heard that you could program the tv to factory settings but I tried that with another remote and all it did was reprogram the remote so that it didn't work anymore. If you have any suggestions as to how I can get the volume to work on my tv, I would appreciate it as well
7/19/2013 12:44:57 PM • Zenith B25A02Z... • Answered on Jul 19, 2013
0answers
Camport
Be the first to answer 7/19/2013 4:15:54 AM • Zenith B25A02Z... • Posted on Jul 19, 2013Be the first to answer
2answers
Color Adjustments....
well it all depends on where the tv is located to, if it is in a room with little or no light( windows, lamps) you will want you brightness to be a lil lighter hince not makin the picture as dark, and vise versa for light rooms, u'll wanna turn the brightness down a lil bit to accomidate this room, as for the others i'd say a lil over 50% on them, thats how my office tv is set up, hope this helps, jason
4/21/2013 3:53:13 AM • Zenith B25A02Z... • Answered on Apr 21, 2013
I have a zenith B25A02Z television. we do not have the remote for this unit and our power went out and we cannot get it back to hdmi. do you know how?/
To select the input to this TV, you must have its original remote control.
4/12/2012 6:01:53 AM • Zenith B25A02Z... • Answered on Apr 12, 2012
How to get camport off
Go into menu go to caption and turn off text screen
12/21/2011 8:30:45 PM • Zenith B25A02Z... • Answered on Dec 21, 2011
NEED TO ADJUST VERTICAL PICTURE
Replace capacitors CX2105 (35 volts 220 Mf), CX2110(35 volts 100Mf), C2104 (50 volts 1 Mf), resolder resistors RX2115, RX2116,R2118,R2119. You will need to also resolder the vertical IC. I think this IC location is IC 2200, its been sometime since I repaired this one.Do not short the pins together with excess solder. The values on the cap may not be exact. Please use the cap value that is removed (remove and replace one at a time). The locations will be correct! This will remove the horizontal lines or bars across the TV screen. You may as well replace capacitors in the horizontal deflection area. By now you have bad caps there. The locations and values are, CX3218 (160 volts 2.2Mf), CX3205 (16 volts at 100 Mf) CX3413 (50 volts 22 Mf) and CX3416 (25 volts 100Mf). Thanks for asking and show all hands of support.
7/14/2011 5:58:05 AM • Zenith B25A02Z... • Answered on Jul 14, 2011
0answers
My panasonic quintrix went onto
you can get a cheap universal remote from almost any retail store i would good luck
12/23/2010 4:31:09 AM • Zenith B25A02Z... • Answered on Dec 23, 2010
Just got the Zenith model
On a TV that doesn't have any A/V inputs, you'll need an RF converter. This device takes the audio and video signals from a source such as your game, and makes a channel 3 or 4 signal that can be tuned in by the set. Converters are available in the TV accessories section of big-box retailers, at Radio Shack, and from many places online. They cost around $20.
Hooking up a converter is easy. You just plug in the A/V cables from the game, connect the output cable to the TV's antenna jack and plug in its power supply (it needs power). There's a connector on the converter to hook up your cable wire again since you have to disconnect it from the TV. It sounds like more trouble than it really is. Maybe 10 minutes.
Happy gaming, and thanks for using Fixya!
10/17/2010 1:51:10 AM • Zenith B25A02Z... • Answered on Oct 17, 2010
0answers
Every time i change the fuse it blows up
You have a shorted Horizontal Output transistor and a bad capacitor or two. Look for a bad resistor and you may have a bad flyback transformer [rare]. But yes the transistor is down!
4/12/2010 3:52:57 AM • Zenith B25A02Z... • Answered on Apr 12, 2010
Zenith B25A02Z TV Logo
63 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
zenith sm2067bt tv set when turn
  • Televison & Video
