20 Most Recent Wolf Range WKGD-2 Gas Double Oven Questions & Answers
Our wolf range won't cool down even though we
pilots set to high
10/27/2013 8:52:15 PM • Wolf Range... • Answered on Oct 27, 2013
I have a 30 inch wolf range I took the door off
A plastic putty knife can help, but the logo is held on with double sided tape and the Wolf parts book always says to order a new logo whenever you order anything that requires removing the logo
10/18/2013 4:20:57 AM • Wolf Range... • Answered on Oct 18, 2013
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
6/20/2012 12:54:34 AM • Wolf Range... • Answered on Jun 20, 2012
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
9/4/2011 1:19:59 AM • Wolf Range... • Answered on Sep 04, 2011
0answers
We have an old wolf
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
4/8/2011 1:45:10 AM • Wolf Range... • Answered on Apr 08, 2011
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
1/22/2011 11:08:33 PM • Wolf Range... • Answered on Jan 22, 2011
0answers
I hear a rattling sound after preheating is
we have this same issue. any resolution? we also have an erro message on the display after use sometimes randomly. Thanks!
8/26/2010 2:50:15 AM • Wolf Range... • Answered on Aug 26, 2010
Can't light ovens
good day,
hope this link below will solve your problem.
ovens
8/2/2010 4:06:59 AM • Wolf Range... • Answered on Aug 02, 2010
2answers
How do I clean a Wolf gas oven? Can I use
Wolf does not recommend use Easy Off, but this is the best cleaner for oven, just don't spray on it, wear gloves, spray on a rag and apply on to the porcelain surfaces, and other good all around cleaner is called Bar keeper's friend and you can pick it up at Safeway or ACE Hardware. Have fun.
3/2/2010 2:40:05 AM • Wolf Range... • Answered on Mar 02, 2010
Soap and water just don't cut the built up grease
Use de-greaser, soap, and brillo pad.
12/1/2009 4:55:13 PM • Wolf Range... • Answered on Dec 01, 2009
TESTING BURNER IGNITION ELEMENT
If you have a crack, your part is no good any longer. We will be happy to send the correct part out to you asap. Just call or email us and we will be sure and get this right out to you. Is your ignitor out or another part? We hope this helps and we look forward to being able to resolve all your parts issues, so please call or email us when you are ready for our assistance.
9/30/2009 7:41:50 AM • Wolf Range... • Answered on Sep 30, 2009
How to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
1/16/2009 3:50:18 AM • Wolf Range... • Answered on Jan 16, 2009
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problemafter power outage. It wouldnt stop beeping with error message relatedto temperature control. My solution was to turn power of at circuitpanel, then reset by pressing and holding the clear button for 5seconds. Also note: in my case I had to close the displaybefore switching the panel off. When I tried to the reset process withthe panel showing, it wouldn\'t reset. To reset othervarious parts of the control panel Instructions said:Time-of-Day ClockImmediately after the oven is installed, setthe 12-hour clock to the current time of day. It may need to be resetafter a prolonged power failure. The clock is visible on the controlpanel during all modes. If the upper oven timer is set, the clock willnot be visible in the upper oven control panel display.SETTING CLOCK1) Touch CLOCK. 2) Touch number pads toset current time of day.3) Touch CLOCK or ENTER to startclock.24-HOUR CLOCKThe time-of-day clock can bechanged from a 12-hour clock to a 24-hour clock. After the clock hasbeen set, touch TEMPERATURE for three seconds, touch CLOCK, and thentouch ENTER. Follow the same sequence to change back to the standard12-hour clock setting.Fahrenheit to CelsiusTheoven can be changed from Fahrenheit (°F) temperature to Celsius(°C).
6/4/2020 6:43:13 PM • Wolf Range Ovens • Answered on Jun 04, 2020
Wolf Range WKGD-2 Gas Double Oven Logo
32 questions posted
Top Wolf Range Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
View Most Popular
Wolf Range Ovens
  • Wolf Range Ovens
Most Popular Question
clean wolf gas oven use
  • Ovens
