20 Most Recent
Brother HL 1450 Laser Printer Questions & Answers
I have 2 brother 1450
sir ,
brother1450 is refelling but print is lo quality .
why,
refil powder is hp.
i am shahzad pakistan
When I put on the power button, all the lights
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Brothers hl 1450.. quit printing in middle of job,
if all of the lights on the printer are flashing it means there is a physical problem with one of the main parts of the machine( power supply, main board, ect.) try unplugging the machine for a few minutes and plugging it back in, if the problem persists you would need to have it checked by a technician
I cann't install Brother HL-1450,
just uninstall the driver if you already installed.
Don’t connect the printer usb cable
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Graphics prints very faint on HL1450. Normal text
You can check the configuration ("Properties" in the "Print..." menu) to see if there is anything you can adjust about the graphics. If it wasn´t like this before, it may be the Tonner cartridge (remanufactured cartridges, if not serviced properly). I dont know with Brothers printers, but with HP Lasers, a wrong driver can also cause this.
Brother printer Drum problem
Several things to check, the P/U roller is warn down, could be the paper sensor or the paper in the tray is set too tight
