20 Most Recent
Brother IntelliFAX 1800C All-In-One Printer Questions & Answers
I change the ink cartridges and then received an
While there are many ways to prevent
Brother printer error code "41?, the most common method is to uninstall Print2PDF file from server. You then need to manually remove the traces that still exist and then reinstall Brother printer. You will then have to upgrade your printer software to its newest version. Another way to prevent Brother printer error code "41? is to make sure that printer spooler is working fine. For better working of the spooler set it in automatic mode instead of the default manual mode.
11/8/2010 5:23:32 AM •
Brother...
Answered
on Nov 08, 2010
What is error 41
error 41 is a critical error with the print head of your machine, you can try unplugging it for a while then plugging it back in but if that doesn't work it will probably need a new head. If the power cycle doesn't work I would suggest buying a new machine
10/4/2010 5:18:51 PM •
Brother...
Answered
on Oct 04, 2010
I keep getting a #41 error message, what does it mean?
From my research ,unfortunately, I have noticed a lot of brother customers have this problem. I did review your manual also only to find that any error listed in the troubleshooting section asks to call customer support without listing what the problem is?
_________________________________________________________
What I found out:
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
If it is still under warranty contact Brother.
If it's out of warranty you can purchase a new print head.
But first try this:
remove cartridges form the machine, with a warm damp cloth wipe off the cartridge head. place back in the fax and unplug power.
wait a few minutes and plug back in.
Also, try this:
Here is a link to your user guide..
after the troubleshooting section there are directions to do a print head cleaning pg. 123
This is my best advice to you.. good luck!
4/12/2010 7:03:24 AM •
Brother...
Answered
on Apr 12, 2010
[email protected] Hi, I'm getting error 41 on
Hi there
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
3/1/2010 6:18:54 PM •
Brother...
Answered
on Mar 01, 2010
I do not have the what I need to install the
Hello sir; If your computer with wizard software, then click "start" go to "setting" after that click on "printer & fax" select adding, then just follow the instruction to finish installation.
2/3/2010 3:26:37 AM •
Brother...
Answered
on Feb 03, 2010
Fax machine says error
unplug all the connections and reconnect everything back.also checkout for any blocked paper or any paper jam.also remove and check out the cartridges from the printer and reinsert.either its the internal circuit failure error and has to be repaired to make it proper.
thanks.
11/3/2009 5:48:09 PM •
Brother...
Answered
on Nov 03, 2009
I dont have a users manuel
Hi Ambrose! Try clicking on the following link (or copy and paste to your browser address window), enter your IntelliFax information, and download the driver. It is in .pdf format, so you need to have Adobe Acrobat Reader installed on your computer (free at Adobe.com). Hope this helps! Halhttp://www.brother-usa.com/manuals/default.aspx
6/9/2009 11:41:12 PM •
Brother...
Answered
on Jun 09, 2009
I AM TAKING CARE OF THE PROBLEM BY TAKING MY MACHINE TO SOMEONE THAT KNOWS WHAT THEY ARE DOING, YOUR PROGRAM IS TOO CONFUSING.
12/17/2008 12:36:15 AM •
Brother...
Answered
on Dec 17, 2008
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
7/7/2008 5:55:21 AM •
Brother...
Answered
on Jul 07, 2008
Error 41
print head defective. cant be fixed anymore.
You need a new fax machine due to the fact that the spare part is more costly than a new one!
2/4/2008 9:14:12 PM •
Brother...
Answered
on Feb 04, 2008
