purchase a different universal remote, and check the packaging to see if it supports your TV's.they may not support all the features of your universal remotes. as far as i know the IR codes are not available.
Hi mwhaken,
You didn't mentioned the brand and model of your remote control, anyway you may try the code below.
ZENITH Codes: 000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/
153
Let me know the brand and model of the remote if the codes above does not compatible with the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sounds like you got a pretty old tv there, its frustrating not to see the RED/WHT/YELLOW plugs on it. This is because this tv was made when that was not out yet. So are you out of luck? No, you ar in luck but it will cost you a little money.
You can purchase one of these RF modulators at Radio shack for like $29.95.
OR
If you have a VCR, Generally they have these plugs out the back of them you would plug the DVD into the VCR in the Video IN. You're TV will need to be on channel 3 or 4 (dending on your vcr) You vcr will need to be powered ON then tuned to VIDEO INPUT. You can do this by using the remote's up/Down channels buttons or pressing input on the remote depending on the VCR.
The VCR will need to be connected to the TV's coaxe port on the back, That port looks like this:
If you do not have a VCR you would purchase a RF modulator you TV will need to be on channel 3! The modulator is connect to the port pictured above above. The DVD is then introduced to the ports on the back of the modulator witch looks like this:
WE hope you found this Very Helpful. This was answered by a human being, That works hard answering FREE questions just for a Thank You!
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
This is likely caused by voltage leakage which happens due to a build up of dust and other contaminants that make its way into the inside of the set.
1. Unplug the set for 4 hours or overnight and leave unplugged.
2. Remove the back cover and vacuum off any excessive dust and dirt.
3. Using a damp cloth, clean around the neck of the picture tube where the large wire connects (this is the main power wire). Wait about 10 minutes and then re-wipe.
You may find that you need to repeat the process a number of times before the problem will be fixed entirely.
Zenith TV troubleshooting
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
Is the tv blinking a code on the light in the front of the tv. If so go to manualslib.com input the model number and look up the trouble code in the manual for the tv.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name of your device in its search box at the right column of the display window. It will help you to find the details easily.
https://homenol.blogspot.com/https://elektrotricks.blogspot.com/https://remotesearch.blogspot.com/https://electrohelponline.blogspot.com/
Do you have the remote? If you do, it should have a quit button for menus like that. The remote is either the MBR3457 or MBR3447. It's on eBay for $10. It is possible that both of them may work for your TV model.
