20 Most Recent
Brother MFC-7225N All-In-One Laser Printer Questions & Answers
Reset drum counter for Brother
Brother Drum Reset Instructions:
This works on the Brother DR-510 and many others.
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
12/24/2010 9:00:07 PM •
Brother...
Answered
on Dec 24, 2010
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place.
2. Lift up the front panel from the device.
3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
Visit my computer
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
