20 Most Recent
Zenith SY3538RK TV Questions & Answers
Zenith system 3 tv will not turn on
I'd say just get a stereo system (amplifier) or something like that, and hook your cable box, vcr, converter or whatever you have right into that. That's what I've been doing for years. Most cable boxes and satellite boxes will control the main volume that goes to the sound output, or you can get a digital stereo with a remote to control the volume that way.
Zenith SY3538RK takes several tries to turn on
hi sir
tv is not a toy it has hazard high voltage parts and you can't remove boards without discharge it and high voltages
if you are familiour with so then do it
but for the fault you have it is quiet clear that you got a dried up capacitors in the power suply board you have to cange 3-5 capacitors in it and evry thing exactly will work perfect
i did 4 replacement capacitors for a friend same type and it is fine
please don't forget to do excelent rate cause i here to help you
regards
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
How do I get the Zenith DVD player to work on a DVD/VCR combo
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote.
VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow).
*Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV.
Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
