20 Most Recent Nikon Inc Coolscan 5000 Questions & Answers
tip
Nikon Coolscan Slide Feeder Jam Solution
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 5000?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
0answers
How to take videos with Nikon B700?
turn on the screen and push record.. the red botten on the back.. but you have to use the screen.. you can not film by using veiw finder
5/6/2020 9:44:50 AM • Nikon Office... • Answered on May 06, 2020
0answers
Nikon Stepper 4s015-119-nk386sx4 Pcb cannot soft
Have you tried contacting Nikon's Technical Support department. They're excellent.
9/20/2013 7:54:52 AM • Nikon Office... • Answered on Sep 20, 2013
The negative mount is jammed
Removed the outer cover - remove the screws on back and bottom then slide it off. Re-latch the tray cover.
I hope this helps. Let me know if you need further assistance.
5/28/2010 2:19:16 AM • Nikon Office... • Answered on May 28, 2010
2answers
After working correctly for several
So, you tried to reinstall the drivers ?
http://h10025.www1.hp.com/ewfrf/wc/g...reitem=sj655cz
Can you see the scanner in Device Manager? Click on Start, right click on My Computer, then choose Properties... . Click on the Hardware tab, then click on Device Manager. Look for any ?'s or !'s that you see. Or, check for the scanner under Imaging Devices. Do you at least see the scanner device? If you do, then you've at least narrowed it down to perhaps an application issue.
What error messages do you get when you try to scan?
Thanks
6/7/2009 11:51:39 AM • Nikon Office... • Answered on Jun 07, 2009
LS400 works ok after re-boot
That means that the USB turns off when you go to hibernate. This means that the USB port is configured to turn off when you go into hibernate to save power but does not come on. This can be chagned in the control panel then power options or power management. So that I can give you more specific instructions kindly provide me with the type of windows that you are using as well as the brand and model of your computer.
9/21/2008 9:06:55 PM • Nikon Office... • Answered on Sep 21, 2008
2answers
Nikon coolscan 3 LS30
This can be a software issue , so better check if there's any software update go ahead update the software of this and that should fix it..
Hope that helps........
9/4/2008 9:10:18 PM • Nikon Office... • Answered on Sep 04, 2008
WE HAVE A NIKON CAMERA
Hi
Some printing is get struck while printing please try with cancel that printing otherwise restart both the system and printer it will solve your problem
Boopathy.T
8/17/2008 6:00:41 PM • Nikon Office... • Answered on Aug 17, 2008
Computer does not recognise sf-210
Which version of your operating system are you running. I most cases, removing and re-installing the drivers will fix this issue
6/20/2008 10:08:19 PM • Nikon Office... • Answered on Jun 20, 2008
Nikon Inc Coolscan 5000 Logo
1 questions posted
Top Nikon Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
CoolScan Nikon
  • CoolScan Nikon
Most Popular Question
nikon coolscan 8000ed recently started
  • Office Equipment & Supplies
