20 Most Recent Brother HL 5140 Laser Printer Questions & Answers
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Brother HL 5140... | Answered on Oct 16, 2017
A black section down one side of the page could be a couple of things.
1) The Corona Wire Cleaner (The sliding piece on top of the Drum Unit normally either Green or Blue) is not at it's correct rest spot which is where the arrow on the slider and the arrow on the drum unit meet.
2) There is something stuck on the drum or in the laser. Check that there is no scraps of paper caught up in the workings.
Printing too far to one side can be caused by a misalignment of the laser. Turning the machine off for a few minutes may rectify the problem. Otherwise the paper is placed in the tray off-center. Make sure the paper uides on the tray are set snug on the paper.
Hope that helps
Brother HL 5140... | Answered on Mar 11, 2016
Try installing the software package that comes with the printer. The software usually loads a helper app that pings the printer and keeps it online.
Brother HL 5140... | Answered on Apr 13, 2015
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Brother HL 5140... | Answered on Jul 17, 2014
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Brother HL 5140... | Answered on Apr 15, 2014
is the Paper feeding thru if not it could be the paper loader in the paper tray which you can fix by finding a object that will sit in there you could also tape it down this sound like it is the paper loader try this and if not Post back
Brother HL 5140... | Answered on Oct 05, 2013
Brother HL 5140 Laser Printer Logo
207 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
HL Brother
  • HL Brother
Most Popular Question
pages printing off center
  • Office Equipment & Supplies
