20 Most Recent
Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Questions & Answers
I have an imation /Apollo
Hi there.I have this same HDD and I don't think your problem is related with any "installation" or softwares. It should work just as a plug-n-play hardware, as mine does. Maybe Ooq Affiat's advice would do, by changing the USB cable. Best luck!
Computer can no longer show my Imation hard drive.
Your harddisk drive is bad. The external drive enclosure is still working and still sending a signal to your computer, but it is not reading the harddrive disk. There is nothing you can do to fix this, unless you replace the hard disk itself. For the data content that is stored in this damage disk, you can recover the files by sending it to bestbuy or office depot where they will have to send it off to a recovery company where it will cause you couple of bills large. Before so, you can try to take the harddisk inside the external harddrive enclosure and test it with a desktop computer via the sata cable connections. If you still get nothing, then yes it is a 110% your hard disk drive is damaged.
Did not show my apollo
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use
asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
WANT TO WIPE HARD DRIVE CLEAN
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
