20 Most Recent
Zenith C27V36 27" TV Questions & Answers
No picture or sound after a few minutes, replaced blown C812 but problem returned
Hello to all, I have a tv zenith model C27V36, and it has a problem I connect it in the series and it does not turn on and I connect it to the network(net) and immediately burns (damages) the horizontal exit that is a trasistor C5905 and it burns (damages) both resistances of the protection,I changed the trasistor C5905 for a trasistor C3997 that is 20 amps and nonetheless it burns it,there are no signs of short circuits. Could the problem be the high horizontal ocsilacion?? But since turning it on it burns(damages) the horizontal exit I do not have way of checking it, because it is automatically damaged . can someone please tell me what to do in this case??? Or where I can find an electronic diagram or a sketch??? Or can someone who has worked on this TV before h
help me out?? It is a zenith model C27V36 of 27 "..
thank you for you help.
No picture, humming noise
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
Zenith c27v36
The short answer is no. You will not need a converter box. This set contains the ATSC tuner required for the new over-air signals.
Dan
Converter box question
This set has the ATSC tuner required for the new over-air standard. No converter is needed.
Dan
Zenith 27" HDTV second antenna input not accessible on TV/remote
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
No Power
try to check the capacitor valuing 400v/150mf or the biggest capacitor,and all 160volts capacitor
Picture flashing
If it is an older "hd" tv it is probably 'hd ready.' Check for adjustments on your source. The tv will most likely only display the highest resolution it is given.
Jumpy picture
If this set uses a picture tube then your problem may be in the vertical deflection circuit. Also an unstable power supply will cause this problem.
Stargazer
TV changes channel changed before all numbers entered in remote
Possibly you're not putting the numbers in fast enough.
If you are then there maybe a problem with the microprocessor responding too quickly to commands.
I've never seen this problem before, but my TV will do the same thing if I don't get the numbers in fast enough.
Stargazer
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
