20 Most Recent
Dell Studio Xps 8100 Desktop Computer (Intel CORE I5 650 1500GB/8GB) (DXPDPM133) Questions & Answers
Dell Studio xps 8100: Motherboard changed, when booting up I get to the f2/f12 screen with have a progress bar and computer turns off?
So picture guy, LOLMost all boards have two power plugs from PSU, (power supply unit)a 20 or 24pin and a 4 or 8pin. The rest from PSU are for hardware, except if you have any video cards in pci-e slots, but they are not truly part of the motherboard they are addon.Then from the case you have power button, reset, pled,hdled.Sata ports on mobo, cpu fan, addon fans, DVD rom.Front panel audio.So now you have taken one memory stick and entered the BIOS, then tried each one.You need to check each stick.Now you put in your hdd erase disk, boot from it and you're going to erase your hdd so it's all clean for a fresh install.Now you throw in the windows disk and you boot from it to install windows.Right !!!
"operation system not fount" after pressing the start button
Turn it off. Symptoms suggest hard drive failure. Use of s taking a physical battering. This may damage data beyond recovery. The drive Take it to a shop. Your other choice: Oddly, freezing the hard drive sometimess temporaily fixes the drive long enough to recover data. Replacement of the hard drive is the likely fix. Unless you want to try to freeze the HD and copy data off of it quickly, only a shop specializing in data recovery might recover such. Hopefully youhave backed up data to another drive. You might want to consider a new laptop, after you eye the possible cost of repair and/or data recovery.
Studio XPS 9100 - I cannot access the internet from this computer consistently and shutting down takes 25 minutes
Always include the version of Windows in your posts.
Could have been a RAM problem if you got 4 beeps and you seem to have resolved that by reseating the modules. But the RAM error may have caused some corruption to a file on the hard drive.
Assuming the diagnostics pass, you can reboot and press F8 before Windows starts to load. Select Last Known Good. If that gets you to the desktop without errors, shut down normally and reboot normally, and you should be good to go.
You may also want to run chkdsk on the hard drive:
Click: Start>run
Type in: chkdsk C:
Click OK
Accept the offer to run chkdsk at next boot and then reboot. chkdsk will run before Windows loads. It may take a long time, depending on size of your hard drive, so be patient.
Rapid beeping
Can you specify WHEN and perhaps what was on the screen? What were you doing when the problem started?
Can I charge my PP39L laptop with a USB cable?
the only thing to be aware of is the voltage cannot exceed that required for the laptop . for example if the solar panel puts out 12 volts you will need an adaptor before the usb connection to reduce the power to the voltage for the laptop
Device cannot start code 10
Generally, a code 10 says that the driver was not loaded, which could be the driver is missing or corrupted .
Go to the Dell download center and download the driver for your profire device.
It could be on a driver CD that came with the computer Too
Hi my 17" dell laptop model no:pp31l has stopped working it just says bootmgr is missing
This could be due to a CD or DVD left inside the DVD drive. The laptop may be trying to boot from that instead of the hard disk. Make sure no USB flash drives or CD/DVDs are left connected/inserted. If the laptop is trying to boot from the hard disk then the files on the hard disk may be corrupted. This is hard to correct without risking loss of your data. Try running the diagnostics by pressing the 'Fn' key (keep it pressed) and press the power button to turn the laptop on. You should be able to access the diagnostics from there.
HOW TO GET A CD OUT OF STUDIO 1735 WITH A SLOT
there is a button on the F keys, the top row, it looks like a triagle on top of a line press it and it should eject the disk, if this does not work or you cant find it, go to My Computer and when you see the icon of the disk, right click and click eject on the menu.
How to format my Dell computer
Your drive may be toast. You need to find the right F key (typically F2 or F8 or F12) to open the BIOS menu. Start pounding on one while booting until you find it. You may have to try all 12 F keys. Once you get the BIOS menu (not the boot menu), there should be a device section. Make sure your C: drive is visible to the BIOS. If not, the drive is usually bad and needs replaced. You will need a drive preloaded with WIndows, or you will also need the Dell recovery CD set. However, if the C: drive looks OK, next find the right F key to open the boot menu. There should be options there to boot Windows, Safe Mode, Restore to a previous check point, or recover to factory settings. If this does not work, you will need to get the Recovery CD set from Dell for your model. Be warned this usually destroys all old data files.
Flashing 1 white 3 orange
Hi Royce,
You need to replace your laptop battery - its dead. To prove this, take the battery off and just plug the mains charger in. The light should stay solid white.
Many thanks,
Jon.
