20 Most Recent Zenith D60WLCD Television Questions & Answers
3answers
I want to change the lamp.
One word followed by the reasons
DON'T!
Many who think this is just like changing a light globe end up with numerous halo and ring problems on the screen mucking up the picture.
1) There is a matching sequence with the globe
2) it has to be retuned across the screen so thatthere are no shadow areas, rings and halos. So i't's like a focus that is finely set using an instrument to ensure optimum.
3) the lamp hours are reset inside the unit as well as on the screen.
There are 50 peiple currently who changed their own lamps and now have more problems than they need, most times we can't help them because we don;t know what they fiddled with to begin with.
Please rate my help+_++++Thanks for using FIXYA
11/4/2014 12:09:03 AM • Zenith D60WLCD... • Answered on Nov 04, 2014
I need to reset lamp timer on zenith d60wlcd
With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
6/18/2014 3:14:41 AM • Zenith D60WLCD... • Answered on Jun 18, 2014
How do I reset the replace lamp indicator light on my zenith d60wlcd tv ?
6/18/2014 3:10:15 AM • Zenith D60WLCD... • Answered on Jun 18, 2014
I have a Zenith D60WLCD, I have replaced the lamp and it still will not power up. I there something I need to reset.
You need to reset the lamp counter if it reaches 16,000 hours. The tv will not turn on once this limit is reached. With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
6/18/2014 3:06:02 AM • Zenith D60WLCD... • Answered on Jun 18, 2014
Need to reset lamp timer on zenith d60wlcd please
With the TV off, use the TV remote to press the "?" Button and then enter 9876 and then the enter button. The three lights on the front panel will flash, indicating the lamp counter is reset.
6/18/2014 2:52:18 AM • Zenith D60WLCD... • Answered on Jun 18, 2014
MY ZENITH D60WLCD PICTURE IS VERY DIM. i HAVE
Have you adjusted the brightness settings or any other settings to change the picture?
2/28/2011 4:48:25 AM • Zenith D60WLCD... • Answered on Feb 28, 2011
TV turns off after about a minute flashing red light on lamp indi
your tv is talking to you basically, is telling you that the lamp has to be replaced. this is a common problem with this dlp tvs, when the lamp is bad the shuts off within minutes, so just replace the lamp my friend.
6/30/2009 12:32:24 AM • Zenith D60WLCD... • Answered on Jun 30, 2009
My lamp inicator flashes red
Okay this tells me something is getting hot and forced shutdown so I would check and see if fans are obstucted, and there RPMs are up to par.
But when in doubt always call the manufacture as they know to whom to take it to for a repair.
Something is causeing this to turn off and its mostlikly the heat, Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
6/26/2009 4:00:53 AM • Zenith D60WLCD... • Answered on Jun 26, 2009
Zenith D60WLCD
Long story short: The blue fog problse is the light engine. Specificaly, the filter for the blue LCD gets to hot and over time starts to burn up and disinigrate. (I just tore my set apart thinking maybe it was the blue panel and found this was indeed the culprit for this problem). As far as a solution? You will either need to replace the light engine (expensive) or replace the light filter which means tearing the thing completely apart. then there is the problem of where to get a replacement filter. Does ANYONE know where? As far as the lamp goes, might be time to replace it. You might be better off just getting rid of that TV and get a new one.
6/13/2009 10:24:52 PM • Zenith D60WLCD... • Answered on Jun 13, 2009
Chance it will go out again?
Zeinth/ LG have fixed this problem with there new light engines, It sound like that is what you are going to replace, However there is a way to fix this without replacing the light engine, this involves several lens adjustments and the shimming of certain Focus lenses, We have done this sucsefuly several times here at the shop so you may want to call around and see if someone in your area know how to do tis
2/21/2008 9:22:39 PM • Zenith D60WLCD... • Answered on Feb 21, 2008
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Unlock zenith tv from hotel code without remote
The hotel mode is set by the remote control , not the control panel.
8/8/2022 2:43:24 PM • Zenith Televison... • Answered on Aug 08, 2022
Where can I find a manual for my Zenith ZG120M alarm clock
Not available online, but there is a video. https://www.google.com/search?q=Zenith+ZG120M+manual ..
7/22/2022 3:24:38 AM • Zenith Televison... • Answered on Jul 22, 2022
My 50' zenith tv clicks on and then goes right back off after about 2 seconds what's the cause of this?
Without a model there isn't a way to give any helpful information
7/11/2022 11:09:37 PM • Zenith Televison... • Answered on Jul 11, 2022
My 60 inch zenith plasma tv goes off in the middle of watching TV but always came back on but now the screen is black but sound still works
Is the tv blinking a code on the light in the front of the tv. If so go to manualslib.com input the model number and look up the trouble code in the manual for the tv.
5/27/2022 6:29:44 AM • Zenith Televison... • Answered on May 27, 2022
Factory reset my zenith c32v36 tv
Does it work correctly with the remote?
12/24/2021 11:27:52 PM • Zenith Televison... • Answered on Dec 24, 2021
Zenith D60WLCD Television Logo
Popular Tags
17 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
need reset lamp timer zenith d60wlcd
  • Televison & Video
