20 Most Recent Sony Ericsson XPERIA X8 Cell Phone Questions & Answers
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sony Ericsson... | Answered on Sep 28, 2018
Probably an issue with the sender or the settings.
Sony Ericsson... | Answered on Jan 03, 2018
You need to specify the Network and Country it locked now?
You can get the Unlock code at here
Mobileunlocksolutions.com and follow the instructions below and unlock it step by step..
Warning : Do not enter any wrong unlock codes on your Sony Ericsson Xperia X8 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson Xperia X8 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sony Ericsson Xperia X8 with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X8 will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X8 phone should now be unlocked.
Sony Ericsson... | Answered on Nov 28, 2017
Hi
Whatsapp relies on a "Data" connection. If you are not in a "Data" network area or your contract has not got "Data" enabled, Whatsapp won't work.
It will, however work on Wifi. Try it on a Wifi network and see if the problem is still present.
Sony Ericsson... | Answered on Mar 29, 2017
hi, i had this same problem with my x10 m p when i got it, if you connect to your home wirless with the phone this should work and allow you to start downloading (note: after the first 3 downloads it should work without wifi connection and do it on 3g), if this doesnt work go to: settings: applications: manage applications: market: clear cache. then hopefully it should start letting you download some apps
from lewis
portsmouth, UK
Sony Ericsson... | Answered on Aug 24, 2016
How to hard reset the Sony Ericsson Xperia X8First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
Sony Ericsson... | Answered on Oct 30, 2015
you dont,you remember your code
Sony Ericsson... | Answered on Jun 18, 2015
You can not directly copy contacts from Sony phone to computer due to the contacts are stored in SIM card and phone's internal memory, but nut the SD card, but you can use some third party app like: Vibosoft Android mobile manager, Coolmuster Android assistant
How to Transfer Sony Ericsson Xperia Contacts to Computer
Sony Ericsson... | Answered on May 14, 2015
did you back them up to google or cloud
Sony Ericsson... | Answered on Feb 13, 2015
First, try this:
  4. Tap Reset phone
The password is user defined, try the second method if you did not set a password.
Good Luck!
Sony Ericsson... | Answered on Aug 06, 2014
www.download-free-games.com
Sony Ericsson... | Answered on Jul 03, 2014
Sonwthing is wrong with your software. You have to do format reset on YOUR PHONE AND THE MEMORY CARD TO!!!! TRY THIS AND IF COUNTINUES OFF/ON GO TO THE SERVICE
Sony Ericsson... | Answered on Jun 19, 2014
Sony Ericsson XPERIA X8 Cell Phone Logo
631 questions posted
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
restore factory setting code sony
  • Cell Phones
