20 Most Recent Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Questions & Answers
Zenith D60WLCD LAMP INDICATOR START BLINKING IN RED AND TV GO OFF
This sounds like a lamp failure. See your owners manual for instructions on replacing the lamp.
10/8/2013 3:30:53 PM • Zenith D60WLCD... • Answered on Oct 08, 2013
My tv zenith is working
Your problem sounds like the projection bulb is going bad. It is the main problem with projection TV's, and is usually very spendy. I would recommend calling Zenith and request a new bulb.
5/3/2011 9:40:33 PM • Zenith D60WLCD... • Answered on May 03, 2011
0answers
We have a zenith d60wlcd.
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
10/16/2010 4:25:48 AM • Zenith D60WLCD... • Answered on Oct 16, 2010
I have blue hue abotom
kwami835,
You have a bad optical engine. This is not that difficult to replace but could be costly.
I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which will walk you through the process and tell you where to get the new engine at the best price.
Thanks for using FixYa and for the generous rating.
hardrocko
9/27/2010 3:08:35 AM • Zenith D60WLCD... • Answered on Sep 27, 2010
4answers
Zenith 60'' LCD TV a blue screen is not sky blue it looks dark blue to black
Go to zenith.com, look under the service icon at the top and then you should see a listing for "Class Action Lawsuit/Settlement". If you follow that link, they'll have specifics listed for this suit that was brought against them (including tv model #s included in the suit). There was an agreement reached to fix/replace affected t.v.s, court date was in Feb. I believe, and just waiting now until they post information on how to proceed.
http://www.zenithservice.com/index_b2c.jsp
Good luck and hope that helps.
7/31/2010 5:25:47 PM • Zenith D60WLCD... • Answered on Jul 31, 2010
Green pixel on screen
If the pixel is there whatever the source of the image then the problem is in  the DMD - the set of LCD screens that is generating the image. Sorry , this is unfixable, if you can't tolerate it you will have to replace the entire DMD and it will be pretty expensive.
6/28/2010 2:58:47 PM • Zenith D60WLCD... • Answered on Jun 28, 2010
Ive got a blue spot on the lower right hand corner
2/26/2010 9:39:25 PM • Zenith D60WLCD... • Answered on Feb 26, 2010
Blue escreen
Call LG they bought zenith and there is a class action suit so you can get a replacement or repair refund from LG
2/26/2010 9:39:12 PM • Zenith D60WLCD... • Answered on Feb 26, 2010
Zenith D60WLCD Repair
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
8/2/2009 2:44:18 PM • Zenith D60WLCD... • Answered on Aug 02, 2009
My zenith hdtv model#m52w56lcd has a green tint.
Go to the Zenith web site. If you have not adjusted any of the default settings for color, brightness etc then a possibility is that your light engine is failing. Just this month a Class action settlement was put in place that entitles owners of this and several other models to have the light engine replaced in home under an extended warranty until July 2010. You should be able to find a toll free number if you follow the link to Class Action Settlement. I did and a service tech is coming to my house next week to replace it at no cost to me. I looked and the parts alone are approx 600 to 1500 bucks. Good Luck!!
2/27/2009 10:37:28 PM • Zenith D60WLCD... • Answered on Feb 27, 2009
2answers
Zenith D60WLCD
I have purchased 2 of the units from Mat and they are core light engines that look worse than the originals. Your best bet is Tri State Module. I have used a couple of theirs and they are quality. Cost is closer to 400.00 and it is a big job to disassemble this unit and replace this light engine. Most likely will take a tech who knows this unit.
12/1/2008 12:33:36 PM • Zenith D60WLCD... • Answered on Dec 01, 2008
60" zenith tv
Call LG electronics, they bought Zenith and fixed my 60inch Zewnith for free , my model is D60WLCD
9/3/2008 5:14:02 PM • Zenith D60WLCD... • Answered on Sep 03, 2008
26PF332026 inch phillips lcd
Go to this link :
http://teleservice.xooit.fr/t46-MODIFICATION-DALLE-LCD-QD26-EQUIPER-CHEZ-PHILIPS-ET-THOMSON.htm
Sorry, it's in French, but there are pictures of the modification to do.
6/23/2008 3:17:35 PM • Zenith D60WLCD... • Answered on Jun 23, 2008
Zenith Projection TV blurred
out of focus
6/1/2008 9:14:32 PM • Zenith D60WLCD... • Answered on Jun 01, 2008
3answers
My Zentith D60WLCD has a green tint
some transitor is gone bad,you better send it for repair
5/20/2008 12:18:06 AM • Zenith D60WLCD... • Answered on May 20, 2008
2answers
Lcd tv picture,on start up
is this a rear projection tv? a table top one? how old is it because if it's over a few years old, then it sounds as if the bulb may be going out but without having more info, it's hard to give an accurate advice.. please let me know if this helps..
3/22/2008 4:57:36 PM • Zenith D60WLCD... • Answered on Mar 22, 2008
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
36 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
blue escreen
  • Televison & Video
