20 Most Recent Zenith ZEN400SP Remote Control Questions & Answers
Program mbr3447 remote
Programming procedure is too much to type in, and is not practical. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
10/19/2013 9:44:37 AM • Zenith ZEN400SP... • Answered on Oct 19, 2013
CODIGO PARA TV MODELO
Buenas tardes,compre un televisor tcl mi abuela lo bloqueo la pantalla y no encuentro manera de desbloquearlaquiero saber si existe un codigo universal para desbloquearlo y no perder el aparato. Gracias de antemano pueden enviarme respuesta
6/23/2013 8:16:07 PM • Zenith ZEN400SP... • Answered on Jun 23, 2013
I not cant promagram on my tv emerson
These are the programming instructions: Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code SearchIf after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search. If you wish to get more details, check this.
12/30/2012 4:10:22 PM • Zenith ZEN400SP... • Answered on Dec 30, 2012
ZEN400 manuals needed?
Click here to download the user manual. If you find any difficulty in downloading the same, send your email address to me, and get back a copy of it by return mail.
6/25/2012 11:48:51 AM • Zenith ZEN400SP... • Answered on Jun 25, 2012
Zen410a-eia343-sk64-002
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
4/25/2012 7:57:43 AM • Zenith ZEN400SP... • Answered on Apr 25, 2012
Need codes to program a zenith tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
6/12/2009 5:47:57 PM • Zenith ZEN400SP... • Answered on Jun 12, 2009
In the codes for the
regular or universal remote will not consistantly operate my 19"
zenith tv. Could it be the remote sensor, I installed new batteries.
8/24/2008 7:09:14 PM • Zenith ZEN400SP... • Answered on Aug 24, 2008
Need code to program tv
www.remotecodelist.com ...........T.
4/21/2008 12:06:48 AM • Zenith ZEN400SP... • Answered on Apr 21, 2008
How do I set this for SONY DVD
the code for Sony dvd is 276 for this remote control. I suggest using the Aux button. The entiere user manual and codes can be found at
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/zenith/zen100-700-manual.zip&area=other
1/26/2008 7:11:50 AM • Zenith ZEN400SP... • Answered on Jan 26, 2008
Zen400b no codes
codes and an easy guide on how to program it are found @
http://www.remotecentral.com/features/r-zen.htm
"fixya" rating would be great for my time spent finding this one for you. Any problems, give me a hoy back :)
1/16/2008 6:58:23 AM • Zenith ZEN400SP... • Answered on Jan 16, 2008
Zenith-ZEN400B-EIA343-SK16-002
the codees oyu seek and an easy guide on how to program it are here
1/14/2008 5:55:07 AM • Zenith ZEN400SP... • Answered on Jan 14, 2008
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Unlock zenith tv from hotel code without remote
The hotel mode is set by the remote control , not the control panel.
8/8/2022 2:43:24 PM • Zenith Televison... • Answered on Aug 08, 2022
Zenith ZEN400SP Remote Control Logo
21 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
codigo para tv modelo
  • Televison & Video
