20 Most Recent
Pride Go-Go Sport 4-Wheel Questions & Answers
How do i permanently stop the beeper on my pride mobility Go Go Sport 4-wheel scooter?
That cannot be done because it is a safety feature of the scooter. If you're saying that it beeps continuously because of the flat battery, that indicates the battery may not hold its full charge and need replacement. if you remove the beeper you will not be notified when it's time to charge the battery. When the battery is charged, does it discharge faster than when the scooter was new? If so, then you need a new battery. Replace it and see if the beeper stops. If the existing battery is fully charged, does the beeper stop? If so, all is well, it's the battery issue. If it doesn't stop beeping, you have to take the scooter to an authorized agent to rectify the problem. I believe the battery is reaching end of its life.
What does the controller control? how? for what purpose? i'm in the u.s.a. :)
the controller depending on the wig wag resistance value , (the right or left hand paddle is pressed) will output power to the brake then the motor allowing the scooter to go forward or reverse...
The controller carries out a diagnostic sequence before proceeding to supply power to the motor, some scooters will flash the tiller led or bleep,,, Now the controller when put in reverse mode will send a pulse of voltage to the bleeper...
Regards
Pride Zero Turn 10 - 4 beep code randomly while driving.
It is called the "current limit time out." Apparently the battery needs to recuperate or adjust its charge across the cells. That is another question. What it needs is a few minutes to be turned off. I know this from seeing the manual.
https://youtu.be/PB2JsjU9m3A?si=QEXCzBoW3ni5mWyi&t=122
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
