20 Most Recent
Hush Puppies Kya Sandals Questions & Answers
I purchased a hush puppies
Try gel inserts on them. You can get small ones, like the ones for heels. You can look
HERE to get your own custom soles, which are extremely comfortable and can be put right on the shoe. Not only will it make your shoes comfortable like before, but putting them on your shoes can help your feet in so many more ways. Or you can just buy another pair of the shoes or Dr.
Sholls shoes. I hope this helped.
Shoes resoled
it is possible to get these resoled. I have seen hush puppies resoled several times.
I purchased a pair of
I have found that a simple phone call can do wonders! Companies such as Hush Puppies has built a reputation which I am sure they want to uphold, so customer service and satisfaction is important to them. Their phone number is 1-866-699-7365 (M-F, 9:00 - 7:00). Here is a link to their site as well:
http://www.hushpuppies.com/US/en-US/ContactUs/Form.mvc.aspxI highly suggest a phone call rather than an email. Simply explain what happened (and it wouldn't hurt to say something like "I am a big fan of Hush Puppies and have never had this problem before.") and offer a solution (i.e., you will pay to ship the shoes back if they will send you a replacement pair or fix yours). Companies are more receptive if you already have a solution in mind rather than just calling to complain and vent. And no matter how rude the person on the other end of the phone is, maintain your composure and be abrupt but polite. If the person is not willing to help you (even if they say they are sorry but there is just nothing they can do), ask to speak to the manager/supervisor. ALWAYS get the name (first and last) of the person you are speaking with and make a note of it. If the manager/supervisor does not assist you to your satisfaction then keep moving up the chain.
If after all your efforts they still say "no," then repeat their names and let them know that you are going to report them to the Better Business Bureau (or whatever version you have in your country). Don't be surprised if they change their tune!
Good luck and "walk on!"
Happy shopping!
Oakley screw fell out
1. PLACE THE FRAME ON A FLAT SURFACE WITH THE SCREW HOLE FACING UP.
2. TAKE THE SMALL SCREWDRIVER AND INSERT THE REPLACEMENT SCREW INTO THE HOLE.
3. TURN THE SCREWDRIVER CLOCKWISE TO TIGHTEN THE SCREW UNTIL IT IS SECURE.
4. ONCE THE SCREW IS IN PLACE, MAKE SURE IT IS TIGHT ENOUGH TO HOLD THE FRAME TOGETHER.
3/28/2024 10:20:58 AM •
Clothing...
Answered
14 hours ago
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
12/28/2023 4:24:01 PM •
Clothing...
Answered
on Dec 28, 2023
Are you searching for Handcrafted Polki Jewellery in India?
Polki jewellery is a traditional Indian jewellery style that uses uncut diamonds in its designs. It is a popular choice for weddings and special occasions. There are many Indian jewellery designers and brands that offer handcrafted Polki jewellery, both online and in physical stores. Some popular options include Sabyasachi, Amrapali, and Tanishq.
2/25/2023 9:53:01 AM •
Clothing...
Answered
on Feb 25, 2023
