20 Most Recent Oxo Good Grips Triple Timer Questions & Answers
How to change the hour on the OXO triple grip timer.
change-hour-oxo-triple-grip-timer-b1enchklgluxhkaxylqpxcgq-1-0.jpg The instruction booklet for OXO's Triple Timer Model ## 1071501 can be downloaded here: http://www.oxo.com/download/556_gg_1071501_booklet.pdf
3/19/2015 4:03:01 AM • Oxo Good Grips... • Answered on Mar 19, 2015
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned: set-clock-1061978-oxo-timer-b1enchklgluxhkaxylqpxcgq-1-0.jpg To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
10/10/2017 12:33:59 AM • Oxo Hardware &... • Answered on Oct 10, 2017
What battery does an OXO small kitchen timer need?
battery-oxo-small-kitchen-timer-need-b1enchklgluxhkaxylqpxcgq-1-0.jpg I'm assuming you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here: http://www.oxo.com/download/1183_gg_1127980_booklet.pdf
3/19/2015 3:16:39 AM • Oxo Hardware &... • Answered on Mar 19, 2015
How to set instructions OXO Magnetic Digital Timer
set-instructions-oxo-magnetic-digital-b1enchklgluxhkaxylqpxcgq-1-0.jpg The instruction booklet for your timer is available for download here: http://www.oxo.com/download/1183_gg_1127980_booklet.pdf
3/19/2015 3:01:42 AM • Oxo Hardware &... • Answered on Mar 19, 2015
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned: oxo-digital-single-timer-set-clock-b1enchklgluxhkaxylqpxcgq-1-0.jpg To set clock:
To set timer:
To time activities:
3/19/2015 2:04:04 AM • Oxo Hardware &... • Answered on Mar 19, 2015
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do: need-manual-oxo-1061978-timer-b1enchklgluxhkaxylqpxcgq-1-0.jpg To set clock:
To set timer:
To time activities:
3/19/2015 1:46:16 AM • Oxo Hardware &... • Answered on Mar 19, 2015
2answers
Instructions for oxo model 1061978
instructions-oxo-model-1061978-b1enchklgluxhkaxylqpxcgq-1-0_0.jpg To set clock:
To set timer:
To time activities:
3/19/2015 12:08:19 AM • Oxo Hardware &... • Answered on Mar 19, 2015
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered 5 hours ago
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Micromark MM 9565 Timer. How to set up the timerMM9565micro Mark timer
Question edited for clarity and add a header in order with spaces and CAPS. It appears Micromark got out or the timer business. There is a similar one in another Fixya post, and a link to them. https://www.google.com/search?q=Micromark+MM+9565+timer ..
2/19/2024 10:55:33 PM • Hardware &... • Answered on Feb 19, 2024
How to turn water heating temperature up?
2/18/2024 9:47:44 PM • Hardware &... • Answered on Feb 18, 2024
Oxo Good Grips Triple Timer Logo
1 questions posted
Top Oxo Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Oxo Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Oxo Hardware & Accessories
Most Popular Question
change hour oxo triple grip timer
  • Hardware & Accessories
