20 Most Recent
Agfa Arcus 1200 Flatbed Scanner Questions & Answers
How do I install scanner driver? No installation disc.
If one of the two driver files is a .exe then run that and it should do the rest for you. If the files are .ini or similar then you need to goto control panel, device manager and look for the item with the yellow exclamation mark next to it. Right click and choose install or update. If it asks if you want to install manually click yes, when it asks where to look for the file click browse and locate the two driver files you have. Click ok and it should install successfully.
Hope this helps,
www.PuterCare.com
Scanner agfa
el driver esta en esta pagina:
http://static.agfa.com/digicam_scanner_drivers/scanner/duoscan/index.html
Interfase doesnt work, cable is damaged.
I should be a scsi 2 cable -- 50-pin mini-din male/male...
Double check the scanner and the card, if you don't know the difference between mini-din and regular, let me know and I'll try to find images to show you.
Maggie B
