20 Most Recent Bose Wave radio/CD remote control - Graphite Gray Shelf System Questions & Answers
U need to extend the antenna wire looks likes a small black wire in the back of unit
Bose Wave... | Answered on Aug 05, 2014
i probably wouldnt try souldering them because you have a high chance of melting that wire since it is extremely thin and its usually fiberoptic but you may have something frayed inside the input jack itself like a loose ground or a loose connection i would look their as well. When it comes to music i would throw away the input chords and buy new ones
Bose Wave... | Answered on Jan 11, 2014
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Bose Wave... | Answered on Apr 03, 2012
The problem is in the laser pickup assembly, buy a CD cleaning kit and follow instructions, If that fails! it must go back to Bose for sevice the only way.
Hello
Check its power cord first. If it is OK, check its power supply section inside. There will be a fuse at the power supply rectifer board. Check it. If it is found opened [damaged] never put an other fuse, without proper check to the power supply and main audio amplifier section. There must be some reason for the blow up of this fuse. Without rectifying the fault, replacing an other fuse, may make more components to get damaged, and the repair work may cost more. OK.
Bose Wave... | Answered on Feb 27, 2012
First of all, thank you very much Barbara for choosing FIXYA today for your online technical support needs.
See page 15 of the user's manual for detailed instructions and illustrations on how to set the clock on your device.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Bose Wave... | Answered on Dec 21, 2011
Possibly a loose piece inside...you might need to send it into bose for possible repair/replacement of parts.
Bose Wave... | Answered on Mar 04, 2011
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Bose Wave... | Answered on Dec 02, 2010
Try cleaning the lens using a cotton sdwab and alcohol. If that fails to resolve it, the optics are probably starting to fail. Depending upon which model, the optics may be Sony ones that are readily available and relatively cheap. Any service shop that works on audio gear should be able to help with this. Expect the optics to cost between $10-$40.
Dan
Bose Wave... | Answered on Aug 12, 2009
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Bose Wave... | Answered on Jun 28, 2009
Anything that trips the mains has shorted and should be looked at by a technician. Such devices are potentially a fire hazard and should not used and unplugged from the mains till it can be fixed.
Bose Audio... | Answered on Oct 12, 2019
It will make a noise with the bass going through it. Lights are not fitted on some models.
Bose Audio... | Answered on Sep 28, 2019
24 questions posted
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
turn off alarm bose radio touch turn
  • Audio Players & Recorders
