20 Most Recent
Kodak Carousel 4400 Slide Projector Questions & Answers
I'm testing my 4400. With slide tray loaded (no
Yes!! The projector is equipped with a "dark shutter", which means light is only allowed to exit the projector when a slide is in the gate. That eliminates the "white screen strain" on your eyes when no slide is present. Happy New Year!
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Kodak 140 slide carousel trays jam
The 140 tray with older slides and an older projector is a gamble with slide jams every time!! Slides have a natural curve that gets bigger over time. In addition, as slides age, the corners will begin to de-laminate (aka: "dog-eared" slide). Because the slide slot in a 140-tray is SO NARROW, the least little deformation of the slide from normal will cause the slides not to drop. My recommendation, given the age of the projector, trays and slides, is to get rid of those 140 trays and stick with 80-slide trays. Good Luck !! Jim
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Buttons will not advance carousel
Hardrocko is correct with his analysis. I have attached an image from one of my Service Manuals that may assist you when performing the repair. Good Luck !! Jim
Mississauga
Please let me know what your specific Kodak Slide Projector question is, and I will try to pinpoint an answer for you.
Activating projector
For a model 4000 Carousel, there was no remote. You can lightly depress the "Select" bar by the handle, and that should cycle the projector in Forward. There is no cycling in reverse built into the model 4000, so you must hold down the select button and rotate the tray to the slide number you wish.
Kodak 850h
Your projector most likely has a broken Link, which connects the cycle solenoid plunger to the cycle lever. The buzzing you hear is the cycle plunger in the cycle solenoid. This is a quite difficult repair for a trained tech. Parts are available at: www.micro-tools.com I suggest you contact an authortzed repair dealer to make the repairs.
Can a projector grow dim, or is there another problem?
If the projected image is getting dim,check the following: 1. 120 volts at the wall outlet. 2. Check that the lamp is completely seated in the lamp house / socket. 3. Cloudy appearance of the inside of the lamp. This indicates there is a air leak in the glass casing around the lamp filament. 4. The lamp socket contacts have a build-up of material on them caused by arcing between the socket contacts and the lamp pins NOTE: Any of these items will also drastically reduce lamp life! Good Luck!! Jim
Slides will not advance.buttons do not seem to
1. Does the SELECT button work? If so, hold it & remove the tray (if one is present). Skip to step 3.
2. If the SELECT button doesn't work, remove the slide tray (if one is on the projector) using the emergency tray release in the center hub of the projector. 3. 3. Turn the projector on & try to cycle a few times in reverse. This is how you clear a slide change mechanism jam in the projector.
4. If that didn't work, then either you have a broken cycle circuit wire (usually an orange wire within the projector) or the release wire is trapped under the cycle pad. Refer to the following diagram for the correct "at-rest" position of these 2 contacts. (If you don't feel comfortable doing this, then contact a factory-trained repair dealer).
Good Luck !!
I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
I just dragged this projector out of my
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance. (Some models will have a couple of pre-set advance settings between "manual" and "automatic." These usually advance the slides every three to ten seconds.) Push the tab to the manual setting--this will allow you to use the buttons towards the front of the machine to advance your slides.If moving the tab doesn't work it may be broken or jammed.
Focusing into slide transfer box
Yes, use a shorter projection lens. You didn't say what focal length your projection lens is, but Kodak and many of their OEM vendors made very short focal length lenses.
