20 Most Recent
Lexmark Wheelwriter 15 Series II Typewriter Questions & Answers
Hammer doesn't work when typing
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up. batteries nothing to with any function of the machine except to keep the memory and margins
2/23/2015 2:31:04 PM •
Lexmark...
Answered
on Feb 23, 2015
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
9/14/2013 9:21:57 PM •
Lexmark...
Answered
on Sep 14, 2013
Will not turn on. Is there a reset button?
I'm sorry, there is no reset button. It sounds like the power supply board has failed.This is becoming a common problem with all wheelwriters and it is simply caused by age. A local typewriter repairman should be able to get a power supply and install it.
9/13/2013 9:37:46 PM •
Lexmark...
Answered
on Sep 13, 2013
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
8/25/2013 8:29:41 PM •
Lexmark...
Answered
on Aug 25, 2013
Some keys don't type
If this is a Wheelwriter your keyboard is going bad. Contact Geo. Beters Co. @800-392-8085 for a KB rebuild. They do very good work and are reasonable.DickyO
4/16/2012 5:13:14 PM •
Lexmark...
Answered
on Apr 16, 2012
Need to release left margin, it's stuck in the
Turn the machine off move the carrier back & forth by hand and see if it will go all the way to both ends. If it doesn't look for debris in it's path. If it moves put some WD40 on the silver shaft that the carrier slides on. Put some WD40 on the bfront and rear carrier motot bearings, the front one can be reached from inside the T/W the rear one will require snaking the straw thru the case.
DickyO
9/29/2011 4:36:24 PM •
Lexmark...
Answered
on Sep 29, 2011
