20 Most Recent
Avery 9100 Thermal Printer Questions & Answers
I need Driver for Win7
Sorry to inform you but the manufacturer does not provide the drivers for Win 7. So its not possible to use it with this computer.
The only thing you can do is that you can try to install the XP drivers in compatibility mode in Win 7.
To do that right click on the setup file and click on Troubleshoot Compatibility. Then it will give you the option to select the Win XP, do that and Start the program.
If it gets installed with that, well and good, otherwise can't be used.
New power cord
Radio Shack. Take the device with you to assure you get the proper voltage.
Thanks for your interest in FixYa.com
AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Blinking amber light will feed labels but doesn't print on them
I have had the same problem and just got my printer working. I moved the peel lever to the lower postion and the printer now works without any problem. The user guide says to postion the lever to the up position (inactive) but that caused the amber blinking lights (not recognizing the label properly)when loading labels. Hope this helps
