20 Most Recent
Copystar CS-1815 Printer Questions & Answers
Caller service C6000 in kyocera km-2035
Error C6000 related to fuser unit, you can try to reset to see if it works, other wise you need to replace fuser unit.
try to reset following these steps:
press on the panel the key 1078 1078, this will take you to maintenance mode.
now hite the key 163 And then hit the Start key.
select Execute and press Start key again.
Turn the machine off and on.
Good luck
I’m happy to help further over the phone at
https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Error C6000
This is a fuser problem. Try this to reset:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
I'm trying to 'connect' my
Hi and welcome to FixYa,
Initially, postback the Operating System (OS) of the computer where the Copystar CS-1815 would be connected to.
Offhand, have you tried "Continue anyway"?
Alternately, please click
here. The page list the available drivers for the different Operating Systems. Click on the link with the OS of the computer.
Good luck and thank you for asking FixYa.
Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Copystar cs1815 c6000 code
This is a fuser problem -- here is a reset method:
press enter
press enter
select execute
press enter
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
