20 Most Recent
HEWLETT-PACKARD HP EliteBook Notebook Questions & Answers
Function key and esc are not working
Maybe your screen is already set to the brightest it can be. Does trying to make the screen dimmer work ? (on my HP laptop f3 increases the brightness, f2 decreases it. But perhaps the actual brightness is not really the problem, there are other settings to adjust the visibility of your screen, for example contrast. I don't know how these can be altered on your model, how you do this is probably different to how it is done on my laptop. If you still experience problems, seek solutions by searching the internet, or one of the many computer forums, especially for you the HP community forum accessible through the hp website,
www.hp.com
5.May.2014
Keyboard not working properly
If some keys are not working you may need to change your keyboard. This is very easy to do. unscrew the screws from the bottom of the laptop and remove the keyboard, check the partnumber and order a new one from e.g. ebay.
Touchpad locked
Hello
Most of the laptops has a button on the top of the Touchpad to lock and unlock. Sometime it's on the keyboard you have to press (fn) and one of the key from F1 to F12 will show the Touchpad logo. You can do it from there.
How to adjust contrast
Are you asking because the screen has gone dark?Darkness is a backlight issue,can be the screen backlight,inverter or the cable itself causing it.Screen too bright can be adjusted via personalization or often keyboard shortcuts that have what looks like a sun symbol on them,the left key darkens when pressed and the right brightens
Unlock touchpad on Elite book 8440p
On some notebooks, the TouchPad can be turned on by pressing an on/off button located near the TouchPad. If the notebook does not have such an on/off button, you can still enable the TouchPad in its settings control panel.
Connect projector
if your using windows 7 go to start menu control panel and then along the left side it should say connect to a projector . click on it and it should give you the option you want
Touchpad
if u hold fn key on your keyboard and press any batton between f4 an f10 it wll work
Blank screen nothing show on the screen. not even
Try pressing F8 at the start-up if it shows a menu choose to boot in safe mode and then perform a system restore. If that do not solve the problem the you have to do a fresh install of windows. If you do have a recovry disk insert and follow on screen instruction else you have to download the ISO from internet and have to burn it on a DVD.
