20 Most Recent Disney DT1300-C 13" TV Questions & Answers
Disney DT1300 13 CRT Television Mickey ear speakers has remote...
Buy a used identical model on eBay for only $20, and swap parts as necessary.
Unsure if date on question is valid - 2011 - but if valid, this is for information only for other people searching.
Disney DT1300-C... | Answered on Feb 20, 2018
Yo tambi?n ando en b?squeda de ese control o c?digo de la tv de Mickey Mouse
Disney DT1300-C... | Answered on Nov 24, 2016
You would need a factory reset on the TV. You will need to call the manufactor for the reset information.
Disney DT1300-C... | Answered on May 07, 2014
287,289,284,280 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Disney DT1300-C... | Answered on Oct 05, 2013
CD loading mechanism has the fault. Might have to replace it.
Disney DT1300-C... | Answered on Jun 06, 2012
You can buy it from most of the electronic spare part selling shops at your town.
Disney DT1300-C... | Answered on Apr 19, 2012
These were made by a variety of people for disney
On the back should be a label with more details and numbers etc. try posting them back
Disney DT1300-C... | Answered on Dec 16, 2011
Hmmm a wild guess perhaps you should try to add channel 0 (zero)?
Disney DT1300-C... | Answered on Mar 06, 2011
hi. The colored cord you described are for high definition, there should also be some jacks on the back of the cablevision box that say "video out" "left""right"
Find those, and the video out is the yellow in jack on Mickey, and the Left is the white jack on Mickey
If you can't find those, then use the cable tv out from the box to hook it up to your tv.
This is all that is needed to hook up really, just the coax cable from the box to Mickey.
I know Mickey has a antenna cable jack on the back.
Just run a cable from the box to mickey, put Mickey on channel 3, or 4, depending on what the setting is on the box, and you should be good to go!
Disney DT1300-C... | Answered on Feb 08, 2011
sony dt1300-c disney tv model. dont buy the new freakin disney remote for it because it's too expensive. here is the code for the tv. 039 it's a code for sony tv. just buy you a cheap universal remote and set it up.
Disney DT1300-C... | Answered on Jan 12, 2011
Hello
You just try one amoung the following four digit codes
{ 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141}
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Disney DT1300-C... | Answered on Oct 24, 2010
sony
Disney DT1300-C... | Answered on Oct 23, 2010
Yes,must have the original remote.This tv was made for the Disney Corp. by some small tv company,unknown to the tv universial remotes makers.That why they,don't have a Disney Corp. tvs codes for the universal remotes.Try website like Remotes.com to buy an original remote.
Disney DT1300-C... | Answered on Oct 20, 2010
Disney DT1300-C 13" TV Logo
34 questions posted
Top Disney Televison & Video Experts
Jaime Hernandez
Dalynn Turner
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Disney Televison & Video
Most Popular Question
cannot get around v chip password dt1300
  • Televison & Video
