20 Most Recent Red Hat Enterprise Linux ES 3 Standard Edition Questions & Answers
You might plug in a USB wireless adapter or NIC. That might get you to the internet where you can download the needed drivers for the internal NIC. Or you can look in Device Manager, see what NIC is listed that needs drivers, download that driver set to another computer, then transfer the drivers to the Compaq. In Device Manager, add the drivers for the NIC, directing the search to the USB device where the drivers are located.
Red Hat... | Answered on Oct 15, 2017
hi...
many mobile phone companies don't provide drivers for linux.
But there is a software i would personally recommend to you. Actually its not a software, its a shell script.
Name of the software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
  • connect to mobile devices by IR, bluetooth, USB Cable
  • Send and receive files between computer and device
  • Access Internet from Device by Dial Up Networking
  • Browse files on Mobile device
  • Mount the mobile device on a user specified mount point or communication port.
  • usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
  • Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  • ability to connect to any locked/unlocked USB Internet Modems (Zero Devices)
fully automated connection setup. No manual input is needed except to specify connection name.
http://www.sakis3g.org/versions/latest/i386/sakis3g.gz
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Red Hat... | Answered on Jan 09, 2017
We'd need to know what computer you're using to be able to help here, Linux sometimes needs specific drivers (and sometimes has no available driver at all) for devices to function.
The best bet is to look up what sound device your using, like a sound card, or what motherboard your computer has, and do a google search for that device and "linux driver".
You should find what you're looking for, if it exists, when you do that.
Red Hat... | Answered on Dec 23, 2012
check this post..
http://www.fixya.com/support/t8329347-want_install_tata_photon
Hope this will help you out
Red Hat... | Answered on May 23, 2011
Most of the drivers are supported in the latest fedora versions.Red hat is a standard release versions so some drivers were not available in that case you can update the kernel.So you will get most of drivers.
Red Hat... | Answered on Aug 21, 2010
you can download
http://httpd.apache.org/download.cgi
www.techsolutionspot.com
Red Hat... | Answered on Aug 03, 2010
yes
Register with Sites Like Monster Jobs and search for jobs there. There are plenty of Jobs available for RHCE and RHCT profiles.
If you can let me know your country or region then I would be able to give you a more clear picture of where to look,etc..
Best Regards NextDoorNerd
Red Hat... | Answered on Jul 29, 2010
linux connectn
1st log in the root user
connect the usb modem
run terminal in linux
type following command
wvdialconf /etc/wvdial.conf
wvdialconf will detect the modem
nano /etc/wvdial,conf
jus replace dis wid defaulf setting
modem-/dev/ttyusb0
baud=115200
dial command=atdt
baud=115200
dial command=atdt
init1=atz
init 2=at+crm=1
flow control=hardware
username=internet
password=internet
phone=#777
stupid mode=1
aftr dis open terminal type wvdial &press enter
if u want to disconnect den press clt +c
kindly revert if u need any help
if ur using tata photon + then plz check properly der is a inbuilt software in photon modem if u cant find den follow dat above method
Red Hat... | Answered on Jun 15, 2010
i think that the software that you are trying to install is for the linux platform .please try to select software for the desired operating system
Red Hat... | Answered on Jan 02, 2010
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Red Hat... | Answered on Dec 30, 2009
W32/Sdbot-DIQ is a worm for the Windows platform.
When first run W32/Sdbot-DIQ copies itself to:
<Root>\Funny UST Scandal.avi.exe
<Windows>\Funny UST Scandal.exe
<Windows>\xmss.exe
<Root>\xmss.exe
The worm creates the following files:
<Root>\autorun.inf
<Windows>\autorun.inf
Make sure you Shift-Delete these files!
Red Hat... | Answered on Apr 03, 2009
just download the trial version of kaspersky antivirus its free and scan your conputer its a trial version for just 30 days if you want a full version antivirus then go for avg 8 my suggestion is for now install kasperky n after the trial period install the avg 8 to download kaspersky internet security click the link below
http://209.85.175.104/search?q=cache:VMgSgiTD-dIJ:www.kaspersky.com/de/20814_72814_329+kis+free+dowload&hl=en&ct=clnk&cd=3&gl=in
for avg 8 click the link below
http://209.85.175.104/search?q=cache:ypu2SPFV5dQJ:www.topshareware.com/avg-8/downloads/1.htm+avg+8+for+free&hl=en&ct=clnk&cd=3&gl=in
hope this definately solves this problem
Red Hat... | Answered on Feb 17, 2009
Log in in windows safe mode then log on as administrator then delete the applictions directory ( c:\ program files\( applicatins dirctory) then run some windows registry cleaner like easy cleaner)
Red Hat... | Answered on Dec 27, 2008
SURE Firstly i shall give you the manual removal instructions
and secondly recommeneded free programs for anit virus and anti spyware that i use and recommend
HERE ARE MANUAL REMOVAL INSTRUCTIONS
http://www.greatis.com/appdata/d/f/funny%20ust%20scandal.avi.exe.htm
AND HERE ARE THE PROGRAMS I USE WHICH BASICALLY REMOVES EVERYTHING
1.) AVG FREE ANTI VIRUS
2.) SUPER ANT SPY WARE REMOVER
google them and download them, they are free !
if you are having any problems with the instructions let me know..
There is a Redhat linux version of ClamWin antivirus available at:
http://www.clamav.net/download/packages/packages-linux
Red Hat... | Answered on Dec 26, 2008
regedit - to disable this file from running, delete it. if you want to turn off the registry, boot computer into safe mode (tapping f8 key while booting). if you need to manually uninstall a program, do an F3 search in the registry for the program name as a search string. there can be as many as 500 registry entries for the program... if you adopt the f3, delete, enter, f3, delete, enter, you may be able to uninstall the program's registry entry in as little as 15 minute to 1 hour... best of luck, I am not responsible if you delete a wrong value and crash your computer .... heheheeheheh.
Computers & Internet Logo
28 questions posted
Top Red Hat Computers & Internet Experts
Deepak Dharan...
Deepak Dharan...
rjivaro
Joseph Mueller
Joseph Mueller
Are you a Red Hat Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Red Hat Computers & Internet
Most Popular Question
am using red hat
  • Computers & Internet
