20 Most Recent Craftsman 25 gal Air Compressor 3 12 hp Vertical k 2 Stage Oil Free Pump Questions & Answers
Sears troubleshooting
Sounds like motor is frozen; it happens. Most likely its bad brushes and/or commutator. It will be cheaper to buy new motor or compressor.
10/27/2014 4:38:18 AM • Craftsman 25 gal... • Answered on Oct 27, 2014
I need a manual for craftsman air compressor Model # 919.165230
go to sears, they have them for free
8/30/2014 3:16:20 AM • Craftsman 25 gal... • Answered on Aug 30, 2014
The tank is full but not releasing air through the outlet hose
try and work the air regulator screw next to the manometer.
12/10/2013 1:15:42 PM • Craftsman 25 gal... • Answered on Dec 10, 2013
3answers
Compressor runs to 175psi but
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
2/18/2013 8:48:44 PM • Craftsman 25 gal... • Answered on Feb 18, 2013
Air compressor will turn over a couple of times then it just hums and causes the the breaker to kick off
It sounds like it is a capacity start motor and the capacity has gone bad.
8/12/2012 5:47:24 PM • Craftsman 25 gal... • Answered on Aug 12, 2012
2answers
I replaced the presssure switch, part # Z-AC-0789,
the copper tubing may have a leak or a poor connection at the threads. If flared at the end check for any hairline crack at the flared end. The nut that secures the flared end can be cracked as well
6/15/2011 3:40:42 PM • Craftsman 25 gal... • Answered on Jun 15, 2011
The tank fills with air, but the motor doesn't
Pressure switch is stuck on, dont use this until its fixed!!!!!, you could overfill the tank with excess air, it could be adjustable or the switch may need cleaning/replacing.
3/12/2011 4:44:16 PM • Craftsman 25 gal... • Answered on Mar 12, 2011
Compresor runs and pumps, but does not pump at any
YOU MAY HAVE TO REPLACE YOUR REED PLATE AND OR YOUR PISTON AND RING AND CYLINDER.YOU CAN FIND THE PARTS RIGHT AT SEAR WEB SITE
3/9/2011 6:34:47 AM • Craftsman 25 gal... • Answered on Mar 09, 2011
My new 80 gallon Craftsman
Problem sounds like the type of oil being used. The oil should be a gold color. It will get dark over time but not like oil in a car. Check your owners manual to be sure that the right oil is being used.
Compressors use a 30 weight non detergent oil. If you don't have a manual Go to any Sears Home and garden Department and they will be able to help you.
2/22/2011 3:44:01 AM • Craftsman 25 gal... • Answered on Feb 22, 2011
Is there supposed to be water in the air tank?
yes it will build up. the compressor get very hot.you should drain every day. and have a good water seperator prior to your tools.
2/20/2011 5:50:29 AM • Craftsman 25 gal... • Answered on Feb 20, 2011
Water in the air tank
I don't know about your specific unit, but my compressors have drain valves on the bottom. Mine is like an old radiator drain, but you could have quarter turn valves or screwdriver operated valves, etc. Take a look and post back.
Gary
2/19/2011 4:43:07 PM • Craftsman 25 gal... • Answered on Feb 19, 2011
Compressor fills air tank and when it cycle to
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
2/17/2011 1:51:07 AM • Craftsman 25 gal... • Answered on Feb 17, 2011
Where can i find a
sears parts on line.
2/6/2011 1:52:21 AM • Craftsman 25 gal... • Answered on Feb 06, 2011
I have a 25 gal.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
1/16/2011 7:11:36 PM • Craftsman 25 gal... • Answered on Jan 16, 2011
Craftsman 25 gal Air Compressor 3 12 hp Vertical k 2 Stage Oil Free Pump Logo
26 questions posted
Top Craftsman Air Tools & Compressors Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Air Tools & Compressors
Most Popular Question
compressor fills air tank when cycle
  • Air Tools & Compressors
