20 Most Recent Symphonic SC3913 13 in. Combo Questions & Answers
Tengo un tv de 14
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
1/17/2011 7:00:54 PM • Symphonic SC3913... • Answered on Jan 17, 2011
2answers
Symphinic SC313E cant set channels
Unplug it overnight. When you plug it back in you should get the set-up menu.
3/18/2009 11:43:26 PM • Symphonic SC3913... • Answered on Mar 18, 2009
Symphonic SC3919
most likely your channels are in SAP mode, you need to set them up as stereo via the menu. Remote code should be 044. For VCR. turn TV to channel 2 or 3 then press VCR button
8/28/2008 6:12:55 PM • Symphonic SC3913... • Answered on Aug 28, 2008
Remote
Symphonic TV/VCR combo code in TV mode is 044 Same as Sylvania codes
8/25/2008 9:44:53 PM • Symphonic SC3913... • Answered on Aug 25, 2008
3answers
Connecting to an RCA DTA800 digital converter?
I got the new RCA converter box I followed the on screen info but i'm not getting a signal from my antenna so it doesn't show any channels
6/20/2008 3:44:12 PM • Symphonic SC3913... • Answered on Jun 20, 2008
Symphonic 13"" TV
the code is 044, TV/VCR TV mode. Sylvania codes work for Symphonic
5/24/2008 3:57:24 AM • Symphonic SC3913... • Answered on May 24, 2008
2answers
When I turn on my symphonic tv I just get snow and no sound
If you are seeing snow on your Symphonic TV screen, it could indicate that the TV is not receiving a signal from your cable or antenna. Here are some steps you can take to troubleshoot the issue:
  1. Check the cable or antenna connection: Ensure that the coaxial cable or antenna is securely connected to the TV and the wall or source.
  2. Run a channel scan: Perform a channel scan or auto-programming to ensure that the TV is tuned to the correct channels and that it is receiving a signal.
  3. Check the TV's settings: Make sure that the TV's input is set to the correct source, such as cable or antenna. Also, ensure that the TV's settings are not set to "mute" or "no sound."
  4. Try a different device: If you have another device, such as a DVD player or gaming console, try connecting it to the TV to see if it is able to display video and sound.
If none of these steps work, you may need to contact a professional technician or the manufacturer for further assistance.
2/28/2023 1:49:24 PM • Symphonic... • Answered on Feb 28, 2023
Needing a symphonic tv code for my espn remote
https://codesforuniversalremotes.com/remote-control-codes-for-symphonic-tvs/
4/25/2020 7:44:45 AM • Symphonic... • Answered on Apr 25, 2020
With converter box how to make my symphonic ST42FF TV pick up digital signals
Connect the converter box to TV, (usually rca connectors) connect an antenna to the box, turn it on and search for available channels. In most areas you should receive 10-20 channels.
9/24/2019 10:34:51 PM • Symphonic... • Answered on Sep 24, 2019
Code for symphonic brand tv
Gave to you already.
6/13/2018 10:52:01 PM • Symphonic... • Answered on Jun 13, 2018
Code list for symphonic tv
Symphonic TV 3 Digit Remote Control Codes 198 003 053 155 189
Symphonic TV 4 Digit Remote Control Codes 1280 1384 1483 1484 1024 1031 1036 1105
6/13/2018 8:14:44 PM • Symphonic... • Answered on Jun 13, 2018
Televison & Video Logo
Popular Tags
12 questions posted
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
symphinic sc313e set channels
  • Televison & Video
