20 Most Recent
Weslo Cadence 200 Treadmill Questions & Answers
Regarding my Weslo cadence 200
at the end there is adjustment screws they have to have some way to adjust the belt
the screws are probably covered by tape or plastic plugs the adjuster's most likely are
phillups screws it wont take much to shift the belt maybe a 1/4 turn at a time
let me no if you find it the screws are Ware you first step on the tread mill
hope this helps you
bob
I have a Weslo WLTL97540 treadmill but getting error E2 what it means and what to do?
Error E2 on a Weslo WLTL97540 treadmill usually means that there is a problem with the incline motor. To resolve the issue, try the following steps:
- Unplug the treadmill from the electrical outlet.
- Locate the incline motor and check for any visible damage or debris.
- Clean the incline motor and surrounding area.
- Reconnect the power and attempt to raise the incline.
- If the error persists, you may need to replace the incline motor.
If you are not comfortable performing these steps or if the error persists after trying these steps, consider contacting a professional repair service.
