20 Most Recent
Grundig Mini 300 AM/FM/SW Radio Questions & Answers
How do i shut off the alarm mechanism on the mini
Here's a link to the eton site where you can download and print the manual for your radio. Instructions for the alarm function are on page 7:
http://www.etoncorp.com/upload/contents/307/Mini300_Manual_0107.pdf
Bill B.
San Antonio
Broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Replacement battery for grundig satellite 3400 ? Where is it possible to buy?
I think this unit uses 'UM-1' batteries. They are also known as 'D Cell', 'R20' or 'LR20' batteries. Most good electrical, hardware and some of the larger 'supermarket' stores will have these batteries available. A good quality brand like Duracell or Varta should do the job. There is also two separate smaller 'button' batteries in the unit used to power the clock.
Grundig Radio - Smart ForTwo
Hi Carlie, I apologize, however I am not familiar with the code requirement for Grundig Radio. I recommend that you contact the dealership directly and they should be able to help you.
Sticky outside material on the Grundig G8, any solution?
Rubbing 70-90% alcohol applied on a piece of cloth then spread on the radio will eliminate the sticky substance. May need several application and vigorous rubbing. After the process, my Grundig G8 Traveller II looks better than the original rubbery texture. Cleaner too.
