20 Most Recent
Fisher Price Step and Play Piano Questions & Answers
Take legs off step and play piano
You directed this question at me, but unfortunately this isn't my expertise and I am unable to
provide you with a real solution at this time.
Hopefully one of other experts will be able to
provide you with a real solution.
Thank you for using FixYa.
Fisher Price Step & Play
I assume
No sound when baby steps on the keys (with high volume setting)
You have used alkaline batteries
You have tried replacing your betteries
Tried sliding the power and volume switch off and then back on
If you answer yes for all above then it is time to call Fisher price and ask for replacements.
Install baby capsule
What is a baby capsule? Car Seat?Each car is different to each car seat. I know my insurance company helps out if you ask as does the local police department. Best place to start is with your cars manufacturer.
I wanna install a printer
Check the manufacturers website,,for driver info or what if any printer s and devices u can install to the device,,check manual also good luck,,www.fisher price.com..support and register ur products ,,good luck
Fisher price aquarium cradle swing won't swing
It's been a while since I have dealt with these. There is usually an off switch located along the swing bar check to make sure it is in the on position and that the switch itself hasn't been disconnected. Double check to be sure the swing is level and the safety isn't stopping it from working.
Fisher Price Baby monitor model
Hi there, you can download the manuals for that certain model here:
http://service.mattel.com/us/%2Finstruction_sheets%2F71580pr-0920.pdf
http://service.mattel.com/us/%2Finstruction_sheets%2F71580a-0920.pdf
How do I obtain a
SIMPLY GOOGLE FISHER PRICE AND THEN PUT IN BABY MONITOR AND YOU SHOULD BE ABLE TO GET THE INFO ON LINE.
2ND OPTION WOULD BE GO TO ASK.COM AND TYPE IN MANUAL FOR FISHER PRICE BABY MONITOR AND THE MODEL NUMBER WOULD PROBABLY BE HELPFUL
My Pal Scout needs replacement battery spring..
I would perform a test use of the spring before purchasing it to reach this conclusion. You can call ahead to several part stores that you've identified to carry the spring and request if test use is possible. Then, work with the stores that say "yes". Thank you.
9/30/2022 5:41:42 PM •
Baby Care
Answered
on Sep 30, 2022
