20 Most Recent
Jeep Radios: Genuine 6 Disc Cd Changer Questions & Answers
No sound from radio every thing else works
There are two fuses on car stereos, one to hold the memory and make the panel light up. Look for the second fuse. Both fuses are located behind the radio. You may have to pull the whole radio out to locate it.
How can I fix my
http://www.radio-code.com/ you will have to buy the code and the faster you need the code more money you will pay .... or you can call your local jeep dealer and ask them for the code or where to look for it sometimes in glove box but most places need the sirial number on back of radio to get the right code .....
http://www.tintingbyfredjohnson.com my online audio and supension store
CD's will not play
Nope I havent a clue, as this should have been addressed when the jeep was prepped at the dealer unless you are installing the disc wrong in the player?? Take back to the dealer and ask them to fix it NOW!!! Good Luck
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
Car radio for jeep
Almost all, then you'll need to go over to Scosche.com and select a 'in-dash installation kit' . They provide a dash mounting panel for you to side the new radio's mounting sleeve.
Car radio
We had the same messge wit 2 hours for a week, so we disconnected the battery laft it for an hour reconnected it and it asked for the code again. Luckily we had the codes and its fine.
I would suggest you search the internet for a code then try it again.
Good luck
