20 Most Recent
Symphonic ST4919 19" TV Questions & Answers
Attenna hook up
Yes, This set does not have a digital tuner built in. All over the air signals are now digital. This set will work without a converter if hooked up to standard cable,DVD,VCR or Video game console. If you purchase a DVD with a digital tuner built in you can skip the converter box and hook your HDTV antenna directly to it.
I need the RCU300 or RCU 310 universal remotes
http://support.radioshack.com/support_video/doc67/67859.pdf
That is the manual. Might come in handy if you ever need it, but try these codes. Symphonic............................038, 189, 033
When I turn on my symphonic tv I just get snow and no sound
If you are seeing snow on your Symphonic TV screen, it could indicate that the TV is not receiving a signal from your cable or antenna. Here are some steps you can take to troubleshoot the issue:
- Check the cable or antenna connection: Ensure that the coaxial cable or antenna is securely connected to the TV and the wall or source.
- Run a channel scan: Perform a channel scan or auto-programming to ensure that the TV is tuned to the correct channels and that it is receiving a signal.
- Check the TV's settings: Make sure that the TV's input is set to the correct source, such as cable or antenna. Also, ensure that the TV's settings are not set to "mute" or "no sound."
- Try a different device: If you have another device, such as a DVD player or gaming console, try connecting it to the TV to see if it is able to display video and sound.
If none of these steps work, you may need to contact a professional technician or the manufacturer for further assistance.
2/28/2023 1:49:24 PM •
Symphonic...
Answered
on Feb 28, 2023
Code list for symphonic tv
Symphonic TV 3 Digit Remote Control Codes
198
003
053
155
189
Symphonic TV 4 Digit Remote Control Codes
1280
1384
1483
1484
1024
1031
1036
1105
6/13/2018 8:14:44 PM •
Symphonic...
Answered
on Jun 13, 2018
