20 Most Recent Symphonic ST413C 13" TV Questions & Answers
2answers
I got a symphonic 13 inch tv from my mom and she
try one of these..
RCA 0 0 4 7 ,0 7 4 7 ,1 0 4 7 ,1 1 4 7 ,1 2 4 7 ,1 3 4 7 ,
1 4 4 7 ,0 0 9 0 ,0 0 5 1 ,0 0 9 3 ,0 0 1 9 ,0 6 7 9 ,
0 0 1 8 ,0 1 3 5 ,0 0 3 8
METHOD"
presse TV1 and SET button light on remote is steady enter code ...light goes out.. PRESS SET again and try. Keep trying unhtil unit can be turned on or off, then you know you have the right code. Write it on the back of the TV incase it drops out which can happen.
Please rate my help++++Thanks for using FIXYA
8/2/2022 10:54:00 AM • Symphonic ST413C... • Answered on Aug 02, 2022
ST419E can't get the aux
If you have its remote control, press the button marked "AV/TV/Aux repeatedly, to select the desired input. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/
3/14/2014 8:49:05 AM • Symphonic ST413C... • Answered on Mar 14, 2014
manual
I can't power my TV on or off with the remote control
If you can turn it on with the power button on the set;either the remote control is not working, or the TV is not receiving the signal (light) from the remote,or the circuitry inside the TV is not processing the remote signal.If the power button on the TV works.1. replace the batteries in the remote (again)2. make sure there is nothing in front of the TV
4/2/2013 8:19:28 PM • Symphonic ST413C... • Answered on Apr 02, 2013
I dropped my tv and now it will not turn on. What can I do to solve this problem?
Throw it away or use it for parts. It can be anything. You may have cracked the CRT too which is not fixable.
12/29/2012 6:43:02 PM • Symphonic ST413C... • Answered on Dec 29, 2012
Put tv on video without remote
Going to need an original remote for this (not a universal).
4/9/2012 3:02:49 PM • Symphonic ST413C... • Answered on Apr 09, 2012
I have a tv set that is 12yrs old and now there is
Hi Sheila,
12 yrs of service is already fine. If you are going to send it to repair shop and spend around $50-$100 depend upon the faulty parts and you didn't know how long it will last after it repaired, I've suggest you to upgrade to more high end unit. It will give you more quality picture and experienced the advance technology.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
2/12/2011 12:20:22 AM • Symphonic ST413C... • Answered on Feb 12, 2011
My screen is snowy and I don't have a manual so I
I'm don't think having the user manual will solve your problem. I will explain why further down the page but, as you need a new manual anyway, you can download one (free) from here:
http://www.symphonic.us/pdf/om/ST413C.pdf
This problem is filed under Symphonic ST413C, but problems are often mis-filed. If you have a different model number, please let me know and I should be able to provide the correct manual.
The manual will open in a new browser window. You can then print the file and/or save it to your PC by clicking "File" in the top-left corner of the window, then choose "Print" or "Save As...".
If you are unable to open the file, you will also need to download and install the latest version of Adobe Reader: http://get.adobe.com/reader/
The snow on the screen is usually due to a poor signal or interference. This is more common when two TVs are connected to the same receiver. The natural assumption is that if one TV is OK, and the other is not, then the TV must be the problem, but this is not the case. You may find that you need to connect a signal booster / interference suppressor (one small box will do both) somewhere in the system before both TVs will work.
I suggest you download the manual and see if you can resolve the problem from the TV, but I find this unlikely. The TV is simply displaying the signal from the Dish receiver. If they are connected with an RF/co-axial cable you could try re-scanning. If they are connected any other way and you are using an external input setting on the TV, re-scanning wont make any difference.
If you are unable to solve the problem from TV with the help of the manual and you need further assistance, please reply to me from within this page.
Regards,
BElectric.
1/25/2011 11:50:13 PM • Symphonic ST413C... • Answered on Jan 25, 2011
My tv is stuck in
CLOSED CAPTION SELECTION SLEEP 10 To cancel the sleep timer: Press the SLEEP button repeated-ly until "SLEEP 0" is displayed. You may view specially labeled (cc) TV pro-grams, movies, news, prerecorded tapes, etc.with either a dialogue caption or text displayadded to the program.1) Press the MENU button so that the menudisplay appears on the TV screen.2) Press the CH(annel) ▲ or ▼ button to pointto "CAPTION".3) Press the VOL(ume) ▲ or ▼ button to selectthe mode you wish.4) When done, press the MENU button to exit the menu
Then turn OFF.
I also include your user manual below. It's easier to read in there.
8/21/2010 1:51:42 PM • Symphonic ST413C... • Answered on Aug 21, 2010
0answers
I have a 13 in symphonic .. the picture is stuck on one channel,
is it on freeze ?
5/13/2010 2:19:47 PM • Symphonic ST413C... • Answered on May 13, 2010
ST413B. Is this model digital?
Unsophisticated is the first word that comes to mind when describing a television like this one, making it an ideal choice for those who want something they can use to watch television but don’t care about anything else.. Without cable input, there is little hope to get the picture looking sharp and clear using an ordinary antennae. IT IS NOT DIGITAL AND RUNS ON the old RABBIT EARS.!
1/28/2010 3:55:36 PM • Symphonic ST413C... • Answered on Jan 28, 2010
Screen not showing picture
check on vertical ic supply is it 24vdc otherwise try to replace the ic first
6/7/2009 5:43:10 PM • Symphonic ST413C... • Answered on Jun 07, 2009
3answers
Television question
****. Same problem. No luck on the down from channel 2 thing. Fuckin old crappy tvs.
3/26/2009 7:54:07 PM • Symphonic ST413C... • Answered on Mar 26, 2009
Digital signal
No read this. you may have a lawsuit. February 7, 2008
VIA CERTIFIED MAIL
RETURN RECEIPT REQUESTED
Job Lot Wholesale & Retail Stores #2
86-01 Rockaway Beach Blvd
Far Rockaway, NY 11693
Job Lot Wholesale & Retail Inc.
87-85 Parsons Blvd
Jamaica, NY 11432
Attn.: Yosef Ben-Aderet, Chairman or Chief Executive Officer
Re: File No. EB-08-NY-029
Citation No.: C20083238025
Dear Retailer:
This is an official CITATION, issued pursuant to Section 503(b)(5) of the
Communications Act of 1934, as amended ("Act"), 47 U.S.C. S: 503(b)(5), to
Job Lot Wholesale & Retail Stores #2 and Job Lot Wholesale & Retail Inc.
(collectively "Job Lot") for failure to provide appropriate Consumer Alert
disclosures on analog tuner only television receiving equipment in
violation of Section 15.117(k) of the Commission's Rules ("Rules"), 47
C.F.R. S: 15.117(k). As explained below, future violations of the
Commission's rules in this regard may subject your company to monetary
forfeitures.
On January 30, 2008, agents from the Enforcement Bureau's New York Field
Office visited Job Lot at 86-01 Rockaway Beach Blvd, Far Rockaway, NY
11693, and observed that Job Lot did not have the proper Consumer Alert
VCRs, DVD players, and similar products. For more information, call
the Federal Communications Commission at 1-888-225-5322 (TTY:
1-888-835-5322) or visit the Commission's digital television website
at: www.dtv.gov."
Accordingly, it appears that Job Lot has violated Section 15.117(k) of the
Rules by failing to place conspicuously and in close proximity to the
following equipment, in clear and conspicuous print, the required Consumer
Alert label:
Manufacturer Device Model # Number of Units
Symphonic TV WF24T5 1
Magnavox DVD/VCR MDV530VR 2
Magnavox DVD/VCR MWD2205 2
Magnavox VCR MVR450MG 1
Emerson VCR EWV404 3
FEDERAL COMMUNICATIONS COMMISSION
WASHINGTON, D.C. 20554
1/15/2009 2:32:13 AM • Symphonic ST413C... • Answered on Jan 15, 2009
Video mode wont change to tv symphonic st4814
get the remote an fine input press it tell it go to tv.
1/15/2009 2:07:08 AM • Symphonic ST413C... • Answered on Jan 15, 2009
Universal remote code for my t v
i need the code
12/29/2008 8:04:35 PM • Symphonic ST413C... • Answered on Dec 29, 2008
2answers
When I turn on my symphonic tv I just get snow and no sound
If you are seeing snow on your Symphonic TV screen, it could indicate that the TV is not receiving a signal from your cable or antenna. Here are some steps you can take to troubleshoot the issue:
  1. Check the cable or antenna connection: Ensure that the coaxial cable or antenna is securely connected to the TV and the wall or source.
  2. Run a channel scan: Perform a channel scan or auto-programming to ensure that the TV is tuned to the correct channels and that it is receiving a signal.
  3. Check the TV's settings: Make sure that the TV's input is set to the correct source, such as cable or antenna. Also, ensure that the TV's settings are not set to "mute" or "no sound."
  4. Try a different device: If you have another device, such as a DVD player or gaming console, try connecting it to the TV to see if it is able to display video and sound.
If none of these steps work, you may need to contact a professional technician or the manufacturer for further assistance.
2/28/2023 1:49:24 PM • Symphonic... • Answered on Feb 28, 2023
Symphonic ST413C 13" TV Logo
Popular Tags
26 questions posted
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
tv set 12yrs old now
  • Televison & Video
