20 Most Recent
Polaroid i936 Digital Camera Questions & Answers
# for sd card
You can use any SD card from a department, electronics, or office-supply store.
I have a polaroid i936
you may have placed the batteries the wrong way, or the batteries are empty. Or the contacts are not touching or may be dirty - clean them with the eraser end of a pencil.
I have an auto flash,
Follow below mentioned steps to turn flash on:-
- Rotate MODE DIAL to any one of them Auto, program, portrait, landscape, sport or night mode.
- Press POWER button to turn power ON.
- Press Navigation button (left arrow button), Flash mode change each time button is pressed. you can use UP and Down Arrow button to change settings. Set it to FLASH ON.
- Press OK to confirm settings.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
How do i get this
Buy an SD or SDHC memory card. Depending on the size of the card, you can store thousands or even tens of thousands of pictures on it. You don't have to worry about the brand, as long as you stick with the major brands. You also don't have to worry about the speed.
You might also want to consider a card reader, if your computer doesn't have one built-in.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Camera not working
Unfortunately, if the batteries have corroded then the chances are extremely high that the contacts (and possibly more of the camera's internal electronics) have also been affected by corrosion. It may be possible to clean the contacts yourself, but if there is corrosion internally then the camera is probably not economically repairable.
